brakes problem
Discussion in 'General Maverick/Comet' started by Jims maverick, Jan 3, 2015.
  1. Krazy Comet
    AFAIK about all drum brake vehicles have self adjusting brakes since the early 60s, was a big deal back when... Still was common to see 99 cent brake adjust specials at Goodyear, Firestone etc service centers, till the early '70s...
    As already pointed out they are more for maintaining vs correcting a badly out of adjustment condition, also they only self adjust when backing up... A few quick stops in reverse may help...
  2. Ronald Hopkins
    Ronald Hopkins Member
    Morristown Tennessee
    1972 Comet GT
    I know disc brake cars don't have self adjusters on the front. I'm getting old and don't remember if front drum brakes had them.
  3. rthomas771
    Self-adjusting brake came out in 1963...disc brakes area different design and don't need self adjusting
    Krazy Comet likes this.
  4. Ronald Hopkins
    1972 Comet GT
    Ok. Just couldn't remember if front drums had self adjusters or not.
  5. Bryant
    i hope it doesnt take a minute to stop.
    are saying its doesnt have a lot of stopping power?
    or that the pedal has to travel a alot before it will start stopping?
    did you replace the brake shoes and or drums?
    were the shoes soaked with brake fluid from the leaking wheel cylinders?
  6. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    "Self-adjusters", as stated here by others, make only fine adjustments, and work when applying the brakes in Reverse and then applying them going forward (so it's a 2-step process). Their purpose is to maintain adjustment, not to adjust brakes that were never adjusted to begin with.
    The brakes still need to be adjusted each time a brake-job is performed.
  7. CDL
    CDL Member
    Another thing...Did you bench bleed the master cylinder before installing?
    Crazy Larry likes this.
  8. Jims maverick
    Jims maverick Member
    1970 ford maverick 3.3 liter
    If I didn't bench bleed it do I need to take it out and do it or is it too late or what do I do?
  9. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    You can bleed it on the car but it's a pain in the ass.
