Broke vacuum connector...
Discussion in 'Technical' started by A_Bartle, May 4, 2015.
  1. Krazy Comet
    If there isn't enough room to thread it in you can always use a short piece of pipe(nipple) and coupler to extend it outward... Also the ones used in most Ford V8 applications is round with vacuum taps spaced around it...
  2. A_Bartle
    A_Bartle Stallion Dreamer
    Michigan's Thumb
    1976 Yellow 2-door Maverick
    I saw one of these on line, but I wasn't sure if the size & threads were the same....
  3. Rasit
    Rasit Member
    SE Pennsylvania
    A pipe extractor will work better than an easy out. They are shorter, have more gripping surface and will not snap off like a hardened steel easy out. Not trying to endorse China but this kit is available from Harbor Freight for $9. Tap it in with a hammer and wrench it out...
    71gold likes this.
  4. A_Bartle
    Michigan's Thumb
    Hey guys, thanks for all the great advice and help.... very much appreciated! And a big time thanks to Frank for sending me the part I'll need to make the repair. Wish me luck with the extraction....
    71gold likes this.
