...Broken Ease-Out....
Discussion in 'Technical' started by nickmav70, Oct 16, 2010.
  1. simple man
    simple man Member
    Bunnell,Florida
    If you have access to an oxy-acetylene torch,with a fine tip,start heating the ez-out until it is red and starting to spark. Turn off the acetylene and the pure oxygen will "burn" the ez-out. It will not hurt the broken bolt,so you can try again. Also the heat will help to loosen the broken bolt. Good luck,been there and done that!:)
  2. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Don't matter, will still work and not stick to the cast iron block....
  3. PaulS
    yep, the welding rod is covered with a flux that builds up around the outside of the arc so it isolates the surrounding metal from the welding process. There is also a cutting rod that does the same thing. It will blow down through a pin to make it come out more easily - however the bolt would have to be very big - like 3/4" or larger.
  4. nickmav70
    nickmav70 Nick Maverick
    Dallas, GA
    1971 Ford Maverick
    tried a tungsten carbide grinding burr with a dremel and i did absolutely nothing to the ease out... would cut thought the bolt like butter and i slipped once and hit the hole in the block and it carved out a chunk of that too... need less to say im just gonna put my other engine in it and try something else later... the engine is basically just sat in there any way... no clutch linkage and i hadnt even put the harness, injectors or headers on so it is no big deal to change them out... i appreciate all the help guys :thumbs2:
    guess this engine just isnt gonna cooperate
  5. Earl Branham
    Lugoff, SC
    Don't give up. Just now you can do it at your leisure!
