Bucket Seat Track Dimensions
Discussion in 'General Maverick/Comet' started by jaws81, Jan 11, 2022.
  1. jaws81
    jaws81 Member
    Kokomo
    77 Maverick
    Hey everyone, I have bucket seat tracks for a 76-77 and an earlier set, 73-75 I think. Would it be helpful for people if I did something similar to this for all the spacers and such for each track of both years. I know these tracks are getting harder to find so if this would help people as the fab up spacers and brackets in the future I could do this. I laid the image under it for reference and it is not scaled perfect nor was the picture taken and the perfect "flat" angle, but the dimensions are within 1/16" and should be plenty accurate for what would be needed.
    Just looking for thoughts before I spend the time measuring and drawing all this out. For all I know this information is somewhere else already and I couldn't find it when I was looking!
    Jaybee likes this.
  2. TeeEl
    TeeEl Senior Member
    Colorado
    There are '71-'74 tracks, and '75-'77 tracks. The latter were different due to the raised floor section on the passenger side for the catalytic converter...
  3. Speedy
    Speedy Member
    Dallas, TX
    '71 Comet GT
    Are these interchangeable?
  4. Speedy
    Speedy Member
    Dallas, TX
    '71 Comet GT
    I’m wanting to put 71 buckets in a 77. Can I just swap the tracks?
  5. William623
    Orlando
    1973 ford maverick grabber
    If you use the appropriate tracks they will fit fine.
  6. CaptainComet
  7. CaptainComet
    Found it .... check out the pictures mid-thread on the 1977 bucket seat bottom. There is a riser on the outboard section that the track mounts to and the inboard track is mounted much higher.
    To put early buckets in a 77, using 77 seat tracks, you would need to put the outboard track on some kind of fabricated riser under the floor or between the track and the seat. That passenger seat bottom would end up higher than the driver seat.
    http://mmb.maverick.to/threads/cat-hump-bucket-seat-tracks.80862/#post-841192
