Bucket Seat Track Question
Discussion in 'Technical' started by Maverick Guy, Aug 22, 2003.
  1. Maverick Guy
    Maverick Guy Maverick Enthusiast
    NE Ohio
    Dan, this would be a great tech article. (y) Could you take notes and pictures as you go along and then report on your results?
    Thanks,
    Dave
  2. scott
    scott Member
    new jersey
    1970...302 c4 hookers dynamax (for now)
    it took three trips
  3. Jerry
    Jerry Member
    Woodstock, GA
    77 Maverick 2dr 302, 74 LDO
    Dan,
    I have a set of 74 LDO seats that I was going to try putting in a 77. This is a different problem in that the floor is too high for the seat frame. Interested in swapping?
  4. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Only if they are Tan and no rips ... :)
    Edit: I see in a prior post your seats are blue ... here is what I am thinking:
    Perhaps we could dismantle our passenger seat, trade the bottom portion that contains the unique frame and tracks, swap out the seat cover and reassemble the seat. May take a little time but at least both of our seats will be installed correctly ....
    Let me know ... Dan
  5. Jerry
    Jerry Member
    Woodstock, GA
    I like the idea but am not sure how well it will work. The upholstery clips onto the bottom of the seat frame and isn't the 75 frame shorter than the 74? The 74 frame seems to be the same height on both sides of the seat. I have never seen the later years frame so don't know if this will work or not.
  6. dmhines
    Cumming, GA
    I should have them in my posession soon ... I will let you know ... If you want take some detailed pictures and measurements of your passenger seat and post them or email them to me. That way I will be able to determine if it's a waste of time or not .... Perhaps somebody else on the board will chime in also ... Dan
  7. dmhines
    Cumming, GA
    Here is a picture of the seats ... Looks the same on both sides from this picture ...
  8. scott
    scott Member
    new jersey
    can't you guys just swap inside rails?
  9. dmhines
    Cumming, GA
    Scott ... my understanding is that the frame is completely different and pre-converter rails will not bolt onto a post-converter frame. I guess I'll know more once I have the seats ...
  10. DAB
    DAB MAVERICK/COMET ENTHUSIAST
    Austin, TX
    The 1st is a pictures of a post converter passenger seat. Compare it to the next picture. Notice that the leg on the post converter seat has been removed for this design and the seat track mounts directly to the seat.
  11. DAB
    Austin, TX
    Here are a couple more shots of a post converter seat. It will not sit level on the ground, it will actually fall over. On the other had, the pre converter seat will sit all by itself.
    I hope these help.
  12. dmhines
    Cumming, GA
    Can't you remove the track ... add some spacers in the green area and bolt it back on using longer bolts?
  13. DAB
    Austin, TX
    If you could duplicate the leg on the outside of the seat with some metal tubing, you could weld the leg on and then just use the pre converter rail. (Yes, basically filling in the gap).
    You DO want it to be safe.
  14. Jerry
    Jerry Member
    Woodstock, GA
    Dan, it looks to me like the seats you have aren't set up for the cat hump. The frames on both seats look the same in the pic you posted.
    Doug, is the inside rail on those late model seats bolted directly to the seat frame? I have the later model tracks and if all I have to do is remove the brace on the inside and bolt it to the seat frame that doesn't too hard to do.
  15. dmhines
    Cumming, GA
    I can tell you this ... the seats are supposedly out of a 75 4-door ... So either:
    1. The floor pans on the 4-doors allowed the cat to be set back further so Ford used early type rails on 4-doors
    or
    2. The Seller is incorrect about the year of the car ....
    or
    3. It is an optical illusion and they truly are cat hump buckets ...
    I am still waiting for delivery so I will see ...
