Build Sheet questions
Discussion in 'General Maverick/Comet' started by Jerryfow2, Feb 25, 2007.
  1. Jerryfow2
    Jerryfow2 Member
    Milltown IN
    1972 Grabber/1972 Sprint/1976 Stallion
    Hi All,
    I found my build sheet this morning for the sprint :dancing:(or at least most of the pieces of the build sheet):cry:. After a healthy jig saw type reconstruction I was able to see most of the information. I realize with out a Marti Report some of this information is still a mystery but one thing I was courious about was under the Special Packages box a sub box said PROM. Then the number 1 was listed below that. Is This standard on the sprints? Is there a web site that has the break down of what all this information means?
    Thanks for the help!!
    Jerryfow2
  2. Craig Selvey
    I am sure the PROM is for "Promotion" as this was a special promotion car. I am sure Dennis would like a copy of the build sheet.
    Build sheets are also neat because they tell you what color the pint dabs and stripes are supposed to be on all the suspension and other components.
  3. Mavaholic
    I would definitely like a copy of that as well as adding your Sprint to the National Sprint Registry. Please contact me.
  4. Mavaholic
  5. Craig Selvey
    A couple of things....check to make sure the build sheet is for YOUR car. Sometimes it is for the car in front or behind yours on the assembly line.
    Also.....that build sheet should say if your car originally came with 4 or 5 lugs.
