built ford tough with chevy stuff?
Discussion in 'Non-Ford Engines' started by weirdone, Feb 10, 2011.
  1. PaulS
    So you are going to cut the towers out, install a rack and pinion front suspension, fit an Ls2 engine so the hood wil close, what kind of transmission are you going to use? Are you going to use a Ford 9"?
  2. weirdone
    weirdone gear head
    Fresno, Ca
    75' maverick: i6 250 2 dr, 71 maverick 302 2dr.
    i may have to now that i kno the motor wont fit with the towers. using turbo 350, and 8.8 out of an explorer, they come with posi n 3.73 gears.
  3. Craig Selvey
    If you can't afford two cars....then you probably can't afford this swap. This swap will cost you twice as much as putting in a 302...maybe (3) times as much...especially if you have to pay somebody to do it for you.
  4. mav1970
    I stuck with Ford power but I love transplanting engines into places that they shouldn't be :)
    Check out my photos - you can see that if you remove your towers and use a front engine plate, anything will fit - A LOT OF WORK THOUGH :cry:
    Did I mention a lot of GREENBACKS too :D
  5. Ryan
    Ryan Ford Addict
    Phoenix Az.
  6. mav1970
  7. RobbieG.
    RobbieG. Member
    Phoenix Az.
    75 Maverick, 72 Maverick sprint, 67 Mustang bracket car, 02 F250 4X4
    I've always wanted to put a BBF into a 72 ish Vette. Just to make the Chevy guys cry...LOL
    Go for it.
  8. bmcdaniel
    I wouldn't do it but I don't have a problem with someone else putting an LSx in their Maverick. I've seen several in Mustangs that looked good. A few years ago someone here was putting a V10 Viper motor in their Mav and everyone thought it was cool. With the Chevy, though, most go :naughty:.
    Me, I'd like to do the new Ford 5.0 Coyote :bananaman
  9. 74 GRABBER
    74 GRABBER Member
    Peoria AZ
    1974 grabber, 1995 mustang GT, 1967 mustang coupe, 1956 Caddilac sedan Deville
    This would probably be the best route
  10. Dave B
  11. Craig Selvey
    That is the key. The "I've already got this Chevy motor just laying here" argument usually means they think they can do it cheaper because they already have the motor. It usually ends up costing more. WAY more.
  12. PaulS
    This is not a swap that I would do but its your car and I will give whatever help I can.
  13. maverick75
    Someone on this board actually did this. If you search around you can find the pics. It was ratio411.
  14. Recrdholdr
    Recrdholdr National Record Holder
    London Ontario
    I want a 70-73 Maverick
    Don't listen to these guys DO IT!! I can't wait to see how it turns out. The LS Motors make great power, and if you run the injection, can make more with just a Plug in tuner. If I were to do it I'd buy a front clip so I could get the wiring and computer.:thumbs2: Hell look how many Ford Street rods have chevy motors. In My Eyes the only thing off limits is putting an Import Motor in one. I would have some colorful words for someone who did that.
  15. 65 comet
    65 comet Member
    Colorado
    65 Comet Caliente Hrdtp, 65 2+2 Mustang Fastback 4 spd 53 F100 project 67 Ford 1 ton 4x4 project
    This should tell ya that you can get power out of a chevy if you try hard enough:biglaugh::biglaugh::biglaugh::biglaugh::slap:
