C-4 blows fluid out the overflow
Discussion in 'Drag Racing' started by MikeG747, Mar 7, 2011.
  1. mrbobby
    mrbobby New Member
    maryland
    1971 pro-street
    my 1969 mustang did same thing, installed jaz catch can, problem solved
  2. ghettoshelf
    ghettoshelf Member
    austin texas
    73 grabber 302 auto
    I had the same thing happen on a 347/C4 model a p/u and we installed a catch can and ran a bigger cooler and it solved the problem.
  3. mavman
    mavman Member
    Arkansas
    Shouldn't be getting fluid up that high in the case unless it's overfilled or aerating the oil severely.
    Fluid level should be just above the low line on a cold transmission. Much more than that and it'll puke. Mr. Paul has that covered already though.
    Haven't messed with a C4 lately but on the glides (at least mine, dads and my brothers) we fill it to the low line. Then drive it around to put some heat in it and check it again. Typically they'll be half inch higher on the stick after getting them to 140°. I checked mine once...from cold (75°) to 200° it went from the low line to above the high mark. And from experience I know C4's are notoriously finicky to fluid level.
    If it's a race car it needs a puke bottle anyway. Oil under the tires at 100+ is not fun (speaking from this weekend's experience) but mine wasn't ATF.
  4. MikeG747
    MikeG747 Member
    Arkansas
    Thanks for all the tips guys. :Handshake Got the catch can installed. Hopefully problem is solved. (y)
  5. mrbobby
    mrbobby New Member
    maryland
    1971 pro-street
    what kind did you go with?
  6. MikeG747
    MikeG747 Member
    Arkansas
  7. mrbobby
    mrbobby New Member
    maryland
    1971 pro-street
    where did you mount it?
  8. Killercomet
    Killercomet Member MCCI
    Dirtyburg, WV
    1973 comet
    Was at Performance Auto a few weeks ago and asked the question about fluid coming out the vent on a friends Super Comp C4 and they said to just vent it as well.
  9. MikeG747
    MikeG747 Member
    Arkansas
    I mounted the catch can in the engine bay. (y)
