c-4 trans question
Discussion in 'Transmissions' started by mavmike72, Apr 14, 2009.
  1. PaulS
    The cheapest one you can find that fits. :)
    I don't remember for sure but I think there was something about the 66 289 that was different - I know it has the 6 bolt block but I think there was a 150 tooth flex plate? If you use the 302 157 tooth flex plate you can use any 302 small bell for the cars with the automatic.
  2. Streetdeacon
    Streetdeacon Streetdeacon
    Bellingham, WA
    1977 Maverick 2dr.
    Paul, can a 302 be bolted up to the c4 that is behind a 250 ci.? Would I need a different trans or modify the one I have?
  3. PaulS
    Yes, it is a direct bolt in as long as they are both a column shift or both a floor shift C4. While you have the C4 out you should remove the smaller of the two vacuum modulator lines and plug it at the source. If it isn't a dual line car then it won' have two lines going to the modulator. You should use a green stripe modulator.
  4. Streetdeacon
    Bellingham, WA
    1977 Maverick 2dr.
    Thanks for the answer. The 250 is running well at present, but it is always good to know what the options are if a problem arises or I decide I need more hp.
  5. PaulS
    Street deacon,
    I should make sure you understand that the 302 will use a different flex plate but either the 250 or 302 converter can be used. If you put a mild cam in the 250 converter will give you a slightly higher stall speed behind the 302...
    just making sure.
