c4 2-3 flare under Low power only
Discussion in 'Transmissions' started by noodledood2, Dec 27, 2015.
  1. noodledood2
    noodledood2 Member
    Turlock, CA
    1971 maverick 302
    my c4 on my 302 has a 2-3 flare only under heavy power. Is it possible that this is a modulator issue? i recently rebuilt the c4 (less than 1000 miles ago) and put in a transgo shift kit. the flare has not existed since the beginning. It only happens under low power, when i am stepping on it it shifts perfectly. I do not have an inch-lb torque wrench so i cannot be sure what the band adjustment is. I have ordered a green stripe modulator as mine appears to be bad (vaccuum hose has oil in it and the nipple on the modulator had some drip off of it). Am i missing anything or could this be caused by my modulator? also my fluid is fine.
    i should add that although i do not currently know the torque on the front band it was torqued to spec (and then backed out 1 3/4 turns) when it was originally rebuilt
  2. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    More than likely an issue with the modulator, that's what mine did. Also you can use a ft-lbs torque wrench to adjust the bands. 120 in-lbs=10ft-lbs.
  3. noodledood2
    noodledood2 Member
    Turlock, CA
    1971 maverick 302
    Thanks for the quick reply. I'll get the modulator tomorrow and I'll report back with what happens
  4. Krazy Comet
    Dismal Swamp
    I've never had a issue adjusting bands till snug then backing off the specified amount...
  5. stuarta
    stuarta Member
    Moose Jaw Saskatchewan
    2008 Ranger
    Kind of misleading.
    One place you say low power next is under heavy power.
  6. gregmaverick
    gregmaverick Member
    Salem, OR
    1970 maverick
    • Sonnax "C-ratio" Aluminum billet 2-3 shift servo
    • Performance Automatic PA 26411 C4 Shift Servo
    • TCI 523005 Billet Servo
    I installed the Sonnax. No problems & easy to install
  7. noodledood2
    noodledood2 Member
    Turlock, CA
    1971 maverick 302
    Thanks! ill check it out.
    Oops! i meant to say low power in that first sentence... i proof read it too :slap:
  8. noodledood2
    noodledood2 Member
    Turlock, CA
    1971 maverick 302
    i have an A servo on there. is that not enough do you think?
  9. gregmaverick
    gregmaverick Member
    Salem, OR
    1970 maverick
    Probably not. But, It is difficult to say - if every other possibility has been explored (modulator, vacuum leaks, bands, etc); then I'd say a definite yes. Remember that in most cases, automatics were (are) designed for SSSSSmmmmoooothhh shifting (so mom, pop and baby boo-boo) don't get their necks cracked.
    Mine with the C code, shifts firm (but not back braking), and never flares - even going up a hill.
