C4 compared to AOD
Discussion in 'Transmissions' started by 70GreenMonster, Nov 7, 2015.
  1. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    It's similar but still huge compared to the C6.
    Agreed. the biggest downfall to the AOD is the lack of manual second. I have read about a cure for this and would probably do it if I were to switch to one.
  2. Dave B
  3. Static
    Static Member
    Apache Junction AZ
    1975 Maverick 2 Door
  4. Krazy Comet
    Not that I know of...
    About anything can be upgraded but unless you're going to continually beat on it, probably isn't necessary... I have over 700 drag strip passes on the one that was in my Bird when it had the Trick Flow headed 5.0, cept for a hardened input shaft(orig broke 2nd pass at track), and Trans-Go shift kit it's stock...
    The replacement is a fresh rebuild I bought from a friend, came with Lentech valve body and 3500 stall...
  5. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
  6. Krazy Comet
    For the price of that conversion you can buy a shift controller to use a 4R70W, other than transmission mount there are no other custom pieces necessary...
  7. 70GreenMonster
    70GreenMonster Member
    Space Coast, Florida
    I have had great experience with C6's long ago for handling big torque motors and really impressed recently with the performance and efficiency of a 4L60E in our Astro van behind a w code 4.3L it weighed 4400 lbs on the city dump scales with me in it. we got 5k tow rating and 28 mpg with the air off and cruising around 65 when empty. It had 3.42 rear gears.
    I just want an automatic overdrive with no computer or electronic controls for a light old Ford.
    I'm hoping the trans man doesn't tell me anything really bad about this AOD after he checks it out for me.
  8. 70GreenMonster
    the 700R's and 4L60E's were like the AOD and 4R70W, they were evolutions of an earlier design but the GM's had .70 OD's
  9. Krazy Comet
    AFAIK all the popular automatics have from .67 to .70 O/D, it's the 3.07(thereabouts) 1st gear that makes 700R4 desirable... Still a 4R70W with 2.84 1st isn't that far behind, surely better than Fords three speeds and AOD at 2.40...
    Mavit likes this.
  10. Mavit
    Mavit Member
    Prince george bc
    two muatangs ansd one comet
    The E40d is fords over drive version of the C6 and The AOD is A up dated over drive FMX
    Krazy Comet likes this.
  11. Mavit
    Mavit Member
    Prince george bc
    And I should add that The A4LD is a over drive C3, to bad the c4 was never made into an over drive1
  12. Krazy Comet
    Make that a A4LD... I believe it stands for Automatc, 4-speed, Light Duty
    Were commonly found in Rangers, Aerostars, '87-'93 4cyl Stangs and '87-'88 Turbo Coupes...
    Basically a POS in stock form, few made it past 100-125K mi...
  13. Mavit
    Mavit Member
    Prince george bc
    Yes thanks for the correction the A4LD was not much of a tranny but then the C3 was no prize ether!
