C4 diagnostics and data
Discussion in 'Transmissions' started by PaulS, Aug 20, 2008.
  1. chromed302
    chromed302 Member
    78 mustang cobra ll
    c4 problems.
    Hey Paul, hopefully you can help me i have a 77 c4 case filled green stripe modulator and what its doing is... i can put it in park, neutral, reverse and drive and it does just fine but when i put it in drive its stuck in low gear(1st) and doesn't shift and it wont shift manually from 1st to 2nd to drive just stays in that low gear(1st) i been told to check governor and vacuum modulator and the psi on it i put a new modulator in it and i have it running to a vacuum tree on my intake and the valves in the governor move freely what else can i check out? Thanks!
  2. danford1
    danford1 Member
    White Lake, Michigan
    I don't think anyone reads this forum anymore.
    I asked the question above yours 2 months ago and never got an answer.
    Yes, my trans still isn't fixed. I need to know what to check to fix it...
    Perhaps try to find another trans forum and ask your questions there.
    I hope you are able to find an answer.
    Danford1
  3. Craig Selvey
    Paul is no longer is active on this forum as well
  4. chromed302
    chromed302 Member
    78 mustang cobra ll
    well is there any trans forums that are good that could help me resolve my c4 issue that any of you may know of? Thanks
  5. Rasit
    Rasit Member
    SE Pennsylvania
  6. GreyGhost74
    GreyGhost74 Member
    FL
    1974 Mercury Comet
    Got a c4 that 1st and second always engage, but 3rd and reverse wont until the transmission warms up. And it leaks a lot of fluid. First i thought it was the pan gasket. Replaced that. Now it looks like its leaking from above the pan drivers side rear corner of the transmission pan is where most of the fluid is...
  7. CarlFredrickson
    CarlFredrickson Member
    1965 Mustang
    I have a question I rebuilt my C4 in my 65 mustang and shifts perfect when cold slips when warm new bands new seals and new clutches and first thought was trans was overheating so installed external cooler still starts slipping after driving about half hour
  8. Mavit
    Mavit Member
    Prince george bc
    two muatangs ansd one comet
    if you guys are having transmission problems and need someone to help with trouble shooting
    the place I found that has the best C4 section is Ford Muscle Forum !
    There you will find a bunch of guys that can answer your Questions and they frequently check the C4 section of the forum!
  9. CarlFredrickson
    1965 Mustang
    Sorry didn't update this found problem planetery gears were going out was the problem
  10. Dcarriker17
    Dcarriker17 New Member
    Houston,tx
    Mercury cougar
    Ok so My c4 will only go into reverse fine when it starts uk but when it's warm I have to almost redline it to get it to shift to reverse. Every other gear works.
  11. Mavit
    Mavit Member
    Prince george bc
    Reverse is Activated in the C4 By a Servo piston located on the drivers side of the tranny this piston is Steal with a rubber seal around the outer edge this rubber will crack and leek when it gets old! The Servo piston can be seen from the out side of the tranny by pulling the 4 bolts in the cover. To replace it you would need to remove the pan and Valve body, under the Valve body you will see a linkage on the end of the servo piston that hooks to the hard reverse Band!
    This is some thing that a back yard mechanic can repair him self! Remember if you pull the Servo piston from the out side the link will fall into the pan and the valve body will have to be removed to reconnect the Link between the band and the servo piston!
  12. Kenny8080
    Kenny8080 New Member
    tulsa ok
    66 ford mustang
  13. Kenny8080
    tulsa ok
    66 ford mustang
    trouble with 66 C-4 after rebuild has strong reverse but starts in second no upshift and no 1st gear
  14. 74bronco
    74bronco Member
    willamette valley ,oregon
    73 comet , 74 bronco
    Does anyone know if PaulS has passed away?? he was a awesome guy with great knowledge of the c4 tranny.
  15. captainmack
    captainmack Quad Door
    i do not know but he was a wealth of knowledge that he freely gave. years ago he said he was going to leave this forum due to health issues. Thats all i know.
