C4 freewheels intermittently on startup, won't go into any gear, then will
Discussion in 'Transmissions' started by xpsnake, Aug 9, 2021.
  1. CA189HJN
    CA189HJN Robert Couse-Baker
    Sacramento, California
    1973 Ford Maverick 4-door 302
  2. xpsnake
    xpsnake Bruce
    Maryville, IL (near STL)
    1971 Ford Maverick 2-door
    The first time it happened, I was 150 miles into a 300+ mile leg of the drive and only stopped for < 10 minutes at a gas station so it wouldn't have had much of an opportunity to cool down on a 100 degree day. I continued to drive the car for the season and it's parked for quite a while now. It'll be fun to tear it down eventually and figure out what happened.
  3. xpsnake
    xpsnake Bruce
    Still haven't dealt with this, but another 1,000 miles of driving and it finally happened again last night. This time I tested my theory. When moving from park, it will not engage until I go all the way down to "1", then I can come back up to "D". I'm betting something is indeed sticky in the valve body.
    Krazy Comet likes this.
  4. Krazy Comet
    Agreed, 99% morning sickness is related to high mileage/old age trans.
  5. xpsnake
    xpsnake Bruce
    This transmission was rebuilt in 2016 by a reputable shop, but eventually I'll get in there and take a look.
  6. xpsnake
    xpsnake Bruce
    Haha, man this thing. Happened again today. I'll probably deal with it in the spring. This time it didn't matter if I went up or down the gear selector, until I got the car off high idle and lowered the rpm, then she went right in.
  7. xpsnake
    xpsnake Bruce
    Potentially related is that I have a "wah-wah-wah" cycling vibration on deceleration, off the throttle, that has appeared recently as well. Could be trans or torque converter. U joints checked out fine, pinion angle hasn't changed.
  8. xpsnake
    xpsnake Bruce
    Followup: the freewheeling never happened again after October of 2022. However, today I got the car started for the first time since the winter hibernation and fluid is pouring out of the front pump seal area (I assume) I can see it dripping down from between the bellhousing and the case. I initially thought it was a pan gasket, but closer inspection revealed the reality.
    Guess its finally coming out.
