C4 shifts into 3rd late
Discussion in 'Transmissions' started by Davie, Mar 29, 2023.
  1. Davie
    Davie Member
    Ohio
    1976 Maverick
    Good morning,
    My 1976 Maverick, 302v8, auto, 73k, orig miles, shifts into 3rd about 55mph...
    Anyone know if it's worth installing a new modulator valve ?
  2. Krazy Comet
    I'd check vacuum line to modulator first, a small leak can cause late shifts.
    Also if modulator has single vacuum connection facing rearward, should be adjustable. Use small flat blade screwdriver to back out adjustment approx ¼ to ½ turn, test drive.
    If modulator shows any sign of leakage, replace it.
    TeeEl likes this.
  3. Davie
    Davie Member
    Ohio
    1976 Maverick
    Thanks,
    Line looks good, no leaks.
    I'll try adjusting today...
  4. Davie
    Davie Member
    Ohio
    1976 Maverick
    Installed a new NAPA adjustable modulator; still shifts into 3rd at 55mph... backed the srew out 1-1/2 turns;... still 55mph...
  5. TeeEl
    TeeEl Senior Member
    Colorado
    When do you want it to shift into third?...
  6. Davie
    Davie Member
    Ohio
    1976 Maverick
    Maybe 45MPH...
  7. Krazy Comet
    Under light throttle, should shift into 3rd by 30-35 mph at latest.
    Assuming it hasn't been modified with a Hi-Po shift kit, probably have either have a sticking modulator shift valve(behind modulator pin) or maybe governor is hanging.
    Sorry new the modulator didn't help, it's the first thing to try for late shifting issues.
  8. Davie
    Davie Member
    Ohio
    1976 Maverick
    Pin looks worn on the end... I think I'll make a new one; and try that...
    Thanks for the replies !
  9. funkyole
    funkyole Member
    Homewood junction
    1970 maverick grabber
    make sure you get the length right! check the c4 rebuild thread for the correct one for your application.
  10. Krazy Comet
    Worn pin = shorter pin, cause early shift.
    TeeEl likes this.
