C4 to a 5 speed - what's needed?
Discussion in 'Transmissions' started by MsMegen73, Oct 13, 2014.
  1. rthomas771
    Your driveshaft will fit and work fine...71gold sell the t5 swap crossmember.
  2. GRABBER70
    GRABBER70 Member
    wisconsin
    1970 maverick grabber
    Well the current driveshaft I have is a I6 so I definitely wanna upgrade to a V8 one. What you are saying though is that a stock old school drive shaft will work? What about the crossmember??
    Hoosier Dentman likes this.
  3. bmcdaniel
    I used the stock double-hump crossmember. Turned it around backwards and welded a "back porch" plate on to the rear of it to mount the T5. The T5s mounting pad is about 1 1/2" farther rearward than on earlier trannys. Also had to cut a window in the front of the crossmemeber to clear part of the T5's belly.
    Grabber_73 and Hoosier Dentman like this.
  4. Mel Moeller
    Mel Moeller Maverick Moe
    Twin Falls Idaho
    1971 Ford Maverick, Two 1973 Mavericks, 1974 Mercury Comet
    It sure is a lot easier to buy the T5 cross member set from 71Gold.
  5. bmcdaniel
    I don't know if Frank's crossmember would fit my '70 since it has a narrower tunnel. In my case I had to elongate the crossmember mounting holes to bolt it into the tunnel. An hour or so with a welder and a grinder and I used a part I already owned.
  6. Stefan
    Montreal, QC
  7. rthomas771
    71 gold's crossmembers fit fine in Earl's 70. He has patterns for both AOD and t5's to fit just about any year Maverick/Comet. Even the aftermarket t5 in Terry 1's Comet
  8. bmcdaniel
    Hmmm, too bad he didn't have them in 1997 when I did my swap.
  9. Danielmaverick
    Danielmaverick Member
    Earth
    1970 ford maverick
    Hello, I have a 70 maverick I currently have a t45 in it. I just put in a 347 and Im afraid that the transmission won't hold up to the new torque which is 415. (Is this assumption correct?) if I get a tko600 will I have to make any modification whatsoever particularly to where the transmission brace mounts to?
  10. rthomas771
    The TKO rubber mount is in a different location. Best I can remember its about 1" farther back
