C4 to AOD
Discussion in 'Transmissions' started by Mr Nick, Jul 27, 2015.
  1. satchelmcqueen
    satchelmcqueen Member
    north georgia
    one more question. on my jeep liberty (06) i can lock out over drive and keep it as a 3 speed for hilly conditions. does the AOD have a lock out feature? or do i need to get a 4 speed type automatic shifter or a button of some kind ty? can i keep it as a 3 speed until i need that extra 4th gear for cruising?
    this might answer my question as to whether to go AOD or keep the regular C4 and just re-gear the rear.
  2. 71Mavrk
    71Mavrk Member
    Nevada
    I use a stock floor shifter. The AOD is kind of strange in there is no lock out for AOD. The AODE does but I am not sure if that transmission will fit in a Maverick.
    I have seen some post which say you can lock it out by putting it in second gear or buy a modified vavle body. I never tried because I want it to go into OD.
    Just like any other transmission, if properly adjusted it will downshift when it senses the need.
    Micah
  3. Krazy Comet
    The factory AOD quadrant is P-R-N-O/D-D-L, pulling it to D locks out the O/D(recommended in hills/mountains), but there's no way to hold 2nd unless one does the AOD shuffle(pull back to 1st when it shifts to 2nd)... The modified Lentech valve bodies have a electric lock out that basically mimics AODE/4R70W operation..
    If performed too quickly the AOD shuffle is said to briefly apply the reverse band, but if there is a couple second pause between it shifting to 2nd and the pull back to 1st, supposedly there is no harm done... I ran a stock AOD with a Trans-Go shift kit when the 5.0 was in the Bird, has something like 700 drag passes, still shifts OK though I now wouldn't want to beat it too badly... I have a fresh AOD with Lentech V/B going in my Bird. .
  4. 71gold
    I had an AOD w/trans brake,reverse lock out and OD lockout. Collin has it in his 73 Mav now...that's his car on page 89 of Melvins catalog...:thumbs2:
  5. 71Mavrk
    71Mavrk Member
    Nevada
    Comet,
    Thanks for correcting me. I didnt think the OD was locaked out. I will have to try this.
    Micah
  6. Mr Nick
    Mr Nick One with many questions
    Grapevine, Texas
    1971 Four-Door Maverick, 1962 Cadillac Sedan deVille (soon)
    What is the situation as far as usable motor mounts?
  7. 71gold
    about any auto parts store...:yup:
  8. 71Mavrk
    71Mavrk Member
    Nevada
    I was scrubbing away underneath my car today when I remembered this: You will need new cooler lines.
    What worked for me was to get an AOD set from the junkyard V8 car. I cut them at a straight section just before the motor mount. Put a flare on it, get a union and cut the front section of the originals to match.
    Micah
  9. Mr Nick
    Grapevine, Texas
    I meant which motor mounts do I use since it's an 86 block
    Good to know Micah
  10. 71gold
    I would think all year Mav/Comets that came w/V8, the stands are all the same.
  11. 71Mavrk
    71Mavrk Member
    Nevada
    I used stock Maverick mounts on my '89 5.0.
    Micah
  12. maverick1970
    maverick1970 MCG State Rep
    Missouri
