c4 to take 450hp
Discussion in 'Transmissions' started by JHodges, Dec 28, 2009.
  1. PaulS
  2. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    Godley`s Transmissions in Moultrie Ga. I`ve had one of their Reverse Manual c-4`s and a 3,800 converter In my car for going on 7 years now. Many Racers around the Southeast run Godleys stuff with Very Good results.
    Check it out : http://www.godleytrans.com/pages/ford_trans.html
  3. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    Godley hasn't updated their web site since 2004. Must be busy selling trannys.
  4. JHodges
    JHodges thumper
    Dora Alabama
    I emailed them and they have a c4 with reverse manual valve body and transbrake rated to hold 650hp for $1195. When I get the clip finsijed I plan to buy one
  5. tazbm193
    tazbm193 Member
    florida
    ford
    C4 modifications
    Hi JHodges. At the very minimum you will need a C4 unit out of a V8, there is no way that a unit out of a 6 cyclinder model will hold up. Also advisable
    would be to install a heaver band for 2nd gear, this is available from most performance shops. The piston in the clutch drum assemblies should have every 3rd spring removed. This is where the V8 unit comes into play
    because the piston is designed to hold additional clutch plates, more than the 6cyc transmission does. (More clutches and steels = longevity and better performance) Caution: If you are running a a cam with a lot of duration you must use a stall speed torque converter and to keep from shortning the life of the converter you need to run a 3:91 or lower ratio rear end ratio. Happy Racing
