C4 tranny fluid and filter change ?
Discussion in 'Technical' started by dmhines, Oct 19, 2004.
  1. Craig Selvey
    I personally wouldn't touch it. Let that slepping dog just lay there.
  2. masondr19
    masondr19 Member
    My 76 302/C4 does not have a convertor drain plug. I recently bought the car under similar circumstances-little old lady one owner car, 58k miles, fluid never been changed. Had to do multiple fluid changes, new modulator valve, clean valve body and governor valve, and shifts perfectly now. These are not hard to do and inexpensive if you want to do yourself. Haynes has an excellent manual ["Techbook'] for about 15.00 which covers Ford transmissions in detail with good pictures. No guarantees that this will work, but may be worth a try before springing for new/rebuilt trans. Good luck.
  3. 74MAV
    74MAV Gearhead
    St. Louis MO
    74 Maverick
    My 74 had a drain in the converter until I put a new stall converter in there:D
  4. elliot
    elliot Member
    Boubon MO
    76 4 door 347 paxton and t56
    I think my '76 converter has the drain plug ...
