C4 tranny leak
Discussion in 'Transmissions' started by pax78, Jan 7, 2016.
  1. pax78
    pax78 Member
    Arkansas
    1974 maverick
    Got the leak fixed. Pump wasn't seated in case. Got it going. No leaks shifts like a dream. On to the brakes and body work.
  2. 71gold
    :thumbs2:...:Handshake:
    pax78 likes this.
  3. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    Good deal, did you end up needing the o-ring?
  4. pax78
    pax78 Member
    Arkansas
    1974 maverick
    No o ring. Front pump wasn't seated. Pushed in case crooked. Blowed gasket. New gasket and pressed in straight. 64 65 66 take o ring in outer face of pump. Mine didn't.
  5. Maverocket
    Northwest
    Good to know.
  6. pax78
    pax78 Member
    Arkansas
    1974 maverick
    Yea i never figured out my year,but 71 to 82 takes same rebuild kit. No o ring. Just make sure pump presses all the way in before installing bell housing.
  7. stuarta
    stuarta Member
    Moose Jaw Saskatchewan
    2008 Ranger
    To use an "O" ring the pump must have a groove on the outside. I don't see this groove on yours.
    To properly install the pump and housing guide studs are mandatory.
    What usually happens is the pump is installed but when the housing is attached quite often the bolt holes don't line up so the housing is turned a bit which causes the gasket to move.
    No sealant or glue is required.
