Cal - track question
Discussion in 'General Maverick/Comet' started by Tylermav94, Jul 11, 2014.
  1. Tylermav94
    Tylermav94 Member
    Drumhellar Alberta
    1972 Ford Maverick
    So I've been looking into the cal track system and I'm quite impressed with it. And I think it looks alot nicer than the slapper bar personally. They claim even 7 second quarter mile cars are running with cal tracks today. I was wondering if the standard caltrack suspension system would would standard lyrics with shackles still attached to the back of the frame n leafs? Or would I have to take the shackles out?
    Thanks. :thumbs2:
  2. Mavman72
    Rear shackles remain in place...Cal tracks attach to the front spring eye, and bolt to the rail where the spring was bolted originally...Can you use em with stock shackles and springs??? Sure...But...I would recommend new bushings at the very least in the shackles and the front spring eye...If you are making the kind of power that requires cal tracks...I would recommend their spring set up to go with the cal tracks...
  3. jmgford
    jmgford Member
    Iowa
    Cal-Tracs use (and include) solid aluminum front eye bushings with steel sleeves.
  4. dan gregory
    dan gregory Member
    chesapeake va
    1970 maverick
    My drag car has them,previous owner said they worked great.I`m building it for the trk & hav`nt finished the car yet so I can`t tell you how well they work.I`ve seen them on many drag cars doing a good job at the trk,I believe you should have good luck w/ them once set up properly.
  5. ray-g151
    ray-g151 Member
    Hatboro, PA
    1971 Maverick 412w , 1969 Cougar 427w, 1973 Maverick 306w
    They are without a doubt the best traction device for a leaf spring car. Just make sure you have the pinion angle 3-5 degrees down when installing them. In addition, if you drive on the street, you can back off the load for a better ride. Like said, you will also have to remove the front eye bushings to install the aluminum ones. The only thing I had to change, was to remove the staggered shocks and mount both shocks behind the rear axle. I would only make that change if you are running 10's or faster.
    hectorsalinasx likes this.
  6. Tylermav94
    Tylermav94 Member
    Drumhellar Alberta
    1972 Ford Maverick
    Awesome. Thanks guys, I'll be sure to keep you updated when my order comes through!
  7. hectorsalinasx
    hectorsalinasx Member
    1969.5 Maverick
    I know this might be an old thread but, what all was involved in going from staggered to behind the axle?
  8. Lee Richart
    Lee Richart Member
    Redford, MI
    1973 Maverick LDO 421W
    I have a set on my car and am very pleased with them. I don't race very often, but they took about .2 sec off my 60 foot time compared to slapper bars.
    Lee "THE MAV" Richart
  9. mgabski
    mgabski Member
    1973 Maverick
    Were you having wheel hop issues or anything prior? Or it just allows it to leave harder?
  10. mav man
    mav man Member
    wi
    70mav
    It will hook alot better and eliminate any wheel hop
  11. Hotrock
    Munroe Falls, Ohio
    My Comet never had wheel hop even with the stock suspension. The staggered shocks are designed to help eliminate that issue. Cal Tracs are designed to take the suspension out of the traction equation and send most of the torque directly to the tires.
    Why do you want to remove the staggered shocks? Do you plan on running 10s or quicker?
  12. mgabski
    mgabski Member
    1973 Maverick
    Only reason I asked is because my 60 ft is garbage. Not spinning, but think it's more a tune issue. Anything to improve would be awesome. Haha
  13. Hotrock
    Munroe Falls, Ohio
    How quick are you running and what are your 60' times?
  14. mav man
    mav man Member
    wi
    70mav
    Caltracs keep the staggered shock set up also
  15. mgabski
    mgabski Member
    1973 Maverick
    13.3 is quickest with a 2.1 60 ft. I'm guessing it's more in the tune. 302 with c4. 3000 stall converter 4.10 gear. Bogs really hard off line.
