Cal-tracs installed
Discussion in 'General Maverick/Comet' started by Jimmy2gates, Jun 12, 2010.
  1. Jimmy2gates
    Jimmy2gates Member
    71 mav
    Wow ,i just ajusted the Cal-Tracs and added 2 new main leafs(right and left) and all new bushings, the car is tighter than ever .I think its going to hook harder than it ever has, i can feel the differance in the ride ,stiffer and tighter at the rear end than ever before.:Handshake
  2. Matterick
    Matterick Matt Somerville
    Lake Stevens WA
    if you dont mind me asking. what exactly does a cal-trac do? does it keep the whole back end of the car standing still in the same stance while the front jumps up upon launch? :)
  3. maverick75
    :Handshake
    http://www.hotrodsandhemis.com/Traction.html
  4. Matterick
    Lake Stevens WA
    oh ok! cool! bet those will make quite a difference :thumbs2:
  5. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    Control Wheel Hop During Breaking?
    I might spring for the Cal Traks if they also controled spring wrap up during braking. Asked if they did and got this answer:
    No, they don't help to stop wrap up during braking only acceleration.
    Travis VanKirk
    Calvert Racing Suspensions
    4530 Runway Dr.
    Lancaster Ca 93536
    661-728-9600
    661-728-9615 fax
    I had a '66 Mustang. It would wheel hop VIOLENTLY on a panic stop. Expect the Mavs are the same unless wheel hop is controlled.
  6. maverick75
    Staggered shocks might help, which i think the 66 mustangs didn't have?
    ...but 71+ mavs do have.
  7. Jsarnold
    '72 Sprint
    Good point. Maybe the Mav won't be as bad as the Mustang. But I'd still prefer traction bars that work both ways.
  8. scooper77515
    With Cal-tracs, you can mount shocks on both sides or staggered. They have the mounting points for either way.
    I have them, and new Wilwood master cylinder, and have no issues with wheelhop either way (forward or stopping). 74 model with staggered shocks, and I mounted them to the Caltracs staggered, as well.
    I would think if you are getting wheelhop when stopping abruptly, you have the rear brakes set too firm compared to the front brakes. Back off the tension adjustment and see if that braking wheelhop goes away.
  9. Jsarnold
    '72 Sprint
    Convinced!!
    OK. They're going on my wish list. Thanks for the comments.
  10. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    how important is it to replace the rubber bushings with aluminum ones. I spoke to bryant and the one he put together doesn't have the bushing change to aluminum.
  11. Jimmy2gates
    Jimmy2gates Member
    71 mav
    On my set only the front part were the U bolts go is there a aluminun bushings with steel pins through them on each side ,the back part of the springs (bumper) side have new Neopream bushings ,everything works great .
  12. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I have spy photos of bryant's traction bar that he made himself . . . can't reveal my sources:
