cal tracs
Discussion in 'Drag Racing' started by maverick306, Aug 11, 2014.
  1. Rick
    Rick G8I operations
    Ocala, Florida
    Had em on my last car to 10.30's 1/4 with drag radials, stuck like glue, also had their adjustable shocks. Think we only spun once in 4 years and that was because I didn't have enough air in them 15#. They just worked great on that car, got a 4-link now takes a little more tuning but produces amazing results.
    As for the clunking you mentioned, it sounds like you might be binding them up. make sure the bolts are not to tight they move freely. Then take it to the track and let it eat.
  2. scooper77515
    They don't clunk on takeoffs or while driving fast. Mostly just backing in and out of my driveway, when I come to a stop or move forward, or go up the little bump into the driveway, I may hear a clunk.
  3. Dave B
    Mine don't make any noise.
  4. Mavit
    Mavit Member
    Prince george bc
    two muatangs ansd one comet
    I don't remember the Cal tracs on ether of my cars ever making any noise! you should look at something else!
  5. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Prolly not enough preload. Did you split a piece of heater hose and stick it over the bolt? This dampens any noise when the bolt hits the spring...
  6. scooper77515
    I could at least try the hose on the bolt and see if it changes the sound. Then I would KNOW that it is from the caltracs.
  7. Lee Richart
    Lee Richart Member
    Redford, MI
    1973 Maverick LDO 421W
    If you have a Tractionlok, it will make clunking noises at low speeds on turns. Get some additive from a Ford dealer and it will fix it right up.
    Lee "THE MAV" Richart
  8. Mavit
    Mavit Member
    Prince george bc
    the problem with adding additive to the diff oil is it makes the clutch pack slip do you really want your posi slipping!
  9. scooper77515
    Mine is spooled. No moving parts in there.
    I am pretty sure the sound is the crossbolt hitting the spring as it unloads and reloads.
  10. Lee Richart
    Lee Richart Member
    Redford, MI
    The Ford additive is designed for the Tractionlok and should not make it slip. I know mine doesn't.
  11. Mavit
    Mavit Member
    Prince george bc
    The additive is made to stop the clutch pacs from chattering and the way it stops them from chattering is to make them slip!
  12. dan gregory
    dan gregory Member
    chesapeake va
    1970 maverick
    EVENTUALLY when I get to the trk I`m going to use them for awhile & then switch over to a ladder bar 3 link set up.A little easier to adjust than a 4 link & will work just as well.
  13. stumanchu
    stumanchu Stuart
    Portland, OR
    Frank, I know this thread is from the mists of time, but can you enlighten me as to the exact nature of this technique? I am guessing you do something a bit more modern at this point, but I am very curious about this backwards (upside down?) leaf?
  14. 71gold
    the leaf was turned around backwards, not upside down. this put more spring tention to the front of the spring pack to help keep the springs from wrapping when hitting it hard.
    I still run them this way.
  15. Butters
    Butters Member
    Colorado Springs
    1970 ford maverick
    Or you can do the split mono leaf like the new kids do
