cam lift size
Discussion in 'Technical' started by bomrat, Nov 20, 2012.
  1. dan gregory
    dan gregory Member
    chesapeake va
    1970 maverick
    Go w/ that first rollin thunder you listed,w/ 1.6 rockers it has a 520 lift & not to much duration,would be very snappy with out being overkill & I believe would work well w/ your combo.With this cam I also believe you`ll have no piston to valve issues.
  2. bmcdaniel
    bmcdaniel Senile Member
    As mentioned in post #5, that Edelbrock cam is a pig. Something isn't right with the @.050 duration figures vs, advertised duration given in the first post. IIRC, when I had that cam the @.050 figures were close to 270*, not the 227*/234* listed.
  3. whoozurdaddy
    whoozurdaddy Member
    dell rapids
    1970 2 door maverick
    I decided stage 2 trick flow would be a little much for my 351w
    Im gonna go w a stage 1 .499 and .510 221 225 @ .050 and 275 279 @ .006 should be a torque monster and have nice driveability and still haul ass.
  4. 71gold
    "fast ezefi retrofit efi"
    I know on my stock EFI motor when I went carb. they recommended a...carb. cam...replacement...longer duration.
    I don't know if it would be any advantage to go...EFI cam...shorter duration.
    may check with Fast and see what they say.
    ...:huh:...
