Can Any One Tell Me What This Is?
Discussion in 'Technical' started by 73 Comet, Aug 25, 2011.
  1. darren
    Daves right. It will switch modes under accel and default to defrost. Its a safety default in case the vacuum supply fails. Most cars had small check valves or small vacumm delays installed after production since this is a real common issue. The black can simply stores vacuum but they leaked a lot. The cars that dont flip to defrost likely have had a small valve of amplifier installed in the last 40 years. We ahd tons of TSB's for this as did Ford and GM.
  2. Craig Selvey
    I have yet to find a black can that doesn't leak. A little black silicone around the base of the check valve in the can will cure this.
    Jim.....I know my canister doesn't leak....but I am unsure of the funtionality of the check valve. This is the only current "working" AC car I have. I could see if thes same thing happens on my orange car I suppose (no AC compressor installed, but eveerything else is hooked up). It is VERY NOTICEABLE on my blue car. Maybe because it is a six banger?? :huh:
  3. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    I have mine hooked up straight to manifold vacuum. I've got two cannisters that I bought at pull a part, a metal one and a plastic ball one, but haven't installed either yet. Mine never changes no matter where you put the selector, it's always on defrost. And I don't hear any vacuum leaks under the dash, either. I figured if the selector valve was bad, I'd hear it leaking, but so far I haven't. Haven't gotten around to installing air yet, but hope to this winter.
