Can anyone identify this wire?
Discussion in 'General Maverick/Comet' started by vvr210, Oct 19, 2012.
  1. blugene
  2. CaptainComet
    Thanks Dave ... found that one.
    Well I actually put my glasses on and broke out a flashlight ... had another look at mine. I have a wire bundle that runs along the upper driver side valve cover. It has two wires with that kind of end on it ... both black, and another with an oval shaped end with male and female section... and these are taped back, hooked to nothing. I would swear that the choke for the original motor would have been on the passenger side. Maybe this was emission stuff that I did away with long before the engine swap.
    I am now curious as far as what they would be, too. I did this at least 15 years ago ( I thought perhaps with the motor swap). These are in the same bundle as the wire for the oil pressure sender, and ignition wiring. The wiring for the washer pump is a separate bundle and has a much different end.
  3. simple man
    simple man Member
    Bunnell,Florida
    This is true for my car also. I do not have the yellow with black stripe wire, so it may be for an electric choke. My choke is a heat tube. :huh:
  4. blugene
  5. Dave B
    Does it come from the 3 pugs on the firewall, around the master cylinder?
  6. CaptainComet
    That is where mine originates from ... it is clipped up to the front edge of the cowl and drops down to the intake manifold.
    The only stuff that would have originally been on the car that this is close to this wire loom is the A/C compressor, power steering, and whatever was on the intake. Like I stated earlier, the ignition, water temp, and oil pressure wiring is taped in there too. Jumping from the cowl to the intake, there are two disconnect plugs that continue on, and a third empty one.
  7. vvr210
    vvr210 Member
    Vista,CA
    That's where mine comes from also.......So whats a good wire I can use to hook up my choke?Can I do it off my starter solenoid?
  8. blugene
    I see that on a 77 the choke is on the "S" on the regulator/alternator..
  9. 74LDO
    74LDO Member
    Ohio
    1974 Maverick LDO
    choke pwr
    1974 through 1977 use the white w black tracer for the electric choke. there was no electric choke before that, it was heated from the exhaust manifold gases through a small tube.........
  10. blugene
    Looks like maybe that's what the wire is that this whole thread started about..
  11. vvr210
    vvr210 Member
    Vista,CA
  12. Dave B
    I've got a 73 with one..factory.
  13. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    For an Edelbrock carb .. you just ground the Electric Choke to one of the screws that you loosen to adjust the choke. Works perfect.
