Can Headers produce an engine vibration?
Discussion in 'General Maverick/Comet' started by 55crownvic, Jun 9, 2015.
  1. 55crownvic
    55crownvic Member
    colorado springs
    Still looking for the source of my vibration, and got to thinking, maybe those long tube headers are causing it? Thought about maybe making a solid mounting bracket that would attach to the collector flange and to the transmission or bellhousing some way. Your thoughts?
  2. 71gold
    I don't know of any way they could cause a vibration...:huh:
  3. junrai
    junrai Member
    rancho cordova ca
    I dont see how they could cause that problem all they do is direct the air flow thats coming out of your engine a certain direction. you may have a rocker adjusted too tight not letting your valve open or close all the way or a bent push rod or a fouled plug?
    definitely not the headers
  4. Rasit
    Rasit Member
    SE Pennsylvania
  5. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    if your exhaust is hitting the body anywhere it will cause a vibration
  6. bmcdaniel
    Mine vibrated the neighbor's windows about 1:00 one morning...
  7. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    I think i will vibrate my neighbor's windows tonight they have been acting like it's a drag strip in front of my house lately
  8. 55crownvic
    55crownvic Member
    colorado springs
    ok, I decided to tie the exhaust pipes together right after the header flanges, welded small tabs to the pipes and then bolted them together with another piece of steel. Drove the car today, and almost NO vibration, yeah!! Am thinking about bolting the headers to the transmission, that may make it even smoother.
  9. Krazy Comet
    I take it you don't have a crossover pipe installed???
  10. 55crownvic
    55crownvic Member
    colorado springs
    no crossover pipe.
