Can I swap my stock-style dizzy cap for an "HEI" one with the nipples?
Discussion in 'Technical' started by scooper77515, Oct 30, 2006.
  1. bmcdaniel
    Let me guess, you two stay up late at night and read this stuff to each other?:rolleyes:
  2. scooper77515
    If you considere 6pm to be late...YUP! :D
  3. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    The lower portion of the large cap can be had for 10-15 bux at a parts store.
    They don't wear out, although they can break, but point being you can get one from a boneyard.
    When you go to the parts store and ask for a cap and button, shoot for something around 82 with 302. I think I asked for Crown Vic w/302 to get my stuff.
    When electronic ignition first came out, they continued to use the female cap, so the previous suggestion to use a 75-77 Mav won't get you the cap you want. The large male cap didn't come out till early 80s.
    Anyway... go to the boneyard and get the cap adapter and cover, then go to AZ or other to get the cap and button. It will all work on Duraspark or points distributor.
  4. scooper77515
    THanks for the info... (y)
    Crown Vic it is...
  5. Comet GT 73
    Comet GT 73 Member
    Quebec/Estrie
    Comet GT
  6. scooper77515
  7. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    77's had the big cap.
  8. scooper77515
    Crown Vic it ISN'T...
    I think I need to rephrase my question, after doing a little research.
    Can I find a nippled distributor cap that will fit my stock distributor (small cap) without using this conical adapter I came across? The one on the e-bay search has it, but can I get one by going to AutoZone and asking for a stock cap, and if so, which car(s)?
    The crown vic and the 77 mav both were the same part number and were the big flattened cap...
  9. ratio411
    ratio411 Member
    Pensacola
    The big flat 2 pc cap is what I thought you were looking for.
    It is the only stock male cap that will fit our distributors.
    If there is a small cap with male ends that will retrofit to our distributors, it is a purely aftermarket venture.
    The big cap is better anyway because it is too wide to allow carbon scatter of the spark between cylinders. That is the main reason I use them rather than the male connector issue. I just consider that part icing on the cake.
    Dave
    Btw: If that Summit cap for 24 bux includes all 3 parts in the pic, that is a good price...
    Buy you wires and all while you are at it though. That will add to the value of the 'handling fee' they will charge you. I used Summit brand 8mm wires on mine. They were about 24 bux for a set too.
    Just a thought if you go this route.
  10. scooper77515
    I have to get new wires. Or put 90 degree boots on mine, but new ones look better. Mine are new though, only 500 or so miles, so I might do the boots.
    NAFORD found a part number on a small cap with the nipples from another car, I will check it out and see if it fits. No reason why it shouldn't. Then I will post the part number for future reference :clap:
  11. ratio411
    ratio411 Member
    Pensacola
    I would be interested in that, just for giggles.
    If it looks stock with the plugs installed, I might put one on the Sprint.
    I like good stuff that looks stock, for that car anyway.
    Dave
  12. Comet GT 73
    Comet GT 73 Member
    Quebec/Estrie
    Comet GT
    yes sir! cap, rotor & neck are include... here for 9mm wires http://store.summitracing.com/partdetail.asp?autofilter=1&part=FMS%2DM%2D12259%2DC301&N=700+4294925143+4294864973+4294908331+400070+4294840126+115&autoview=sku
  13. Grabber5.0
    Kansas City, MO
    71 Grabber
    FYI Scott, MSD makes a wire for the old style cap that has a 90* boot on the dizzy end, that's what I'm running. Not what I wanted, but the terminology confuzed me too much when I ordered them, so I switched caps temporarily since I could do so for free.
  14. scooper77515
  15. NAFORD302
    NAFORD302 Member
    SILEX MO
    77 FACTORY V8 AC CAR
    the cap will fit but dumba$$ me did not check rotor so i called and they told me what it looked like and i think it will not work see if it is the same height as the ford one cap part# c200 rotor part# d177 borg warner from o"reillys hope this will help
