Can I swap my stock-style dizzy cap for an "HEI" one with the nipples?
Discussion in 'Technical' started by scooper77515, Oct 30, 2006.
  1. NAFORD302
    NAFORD302 Member
    SILEX MO
    77 FACTORY V8 AC CAR
    rotor wont work trying to find one to match up
  2. scooper77515
    That cap looks just about perfect. Won't it work with the stock rotor? I matched the stock one with that NAPA one, and they seemed like the same height, just that the shaft wouldn't fit in it.
  3. NAFORD302
    NAFORD302 Member
    SILEX MO
    What You Need To Do Is Messure The Depth Of The Inside I Have Not Been Able To Have Both Side By Side No Placse Has Both Look At Yours And When You Go To Napa Or Orilleys Messure That One And See If It The Same Then Your Rotor Will Work I Have Not Gave Up Yet I Am Off Work Tomaro I Will Stop At What Parts Stores I Can And See I Wont Be On Puter So Call Me I Will See What I Can Find Out This Is Not Going To Win I Wont Let It I Have Worked In Auto Parts Way To Long To Loose I Will Win
  4. scooper77515
    I like your attitude... (y)
  5. scooper77515
    If I had the plug wires already, I would have bought the cap and tried it. I tried to snap one of my wires onto the top, but would have had to crimp it pretty good to make it snap on, and then would have to uncrimp them all if I it didn't work and I had to use my stock cap. Didn't want to mess with the wires like that.
    I have to do the steering swap with this paycheck, so maybe I will buy new wires and that cap next payday and test it out...
  6. NAFORD302
    NAFORD302 Member
    SILEX MO
    Email Me Your Adress And I Have A Set Of Wires You Can Have To Try They Are Taylors Pretty Ford Blue
  7. scooper77515
  8. bmcdaniel
    The high voltage rotor is longer than the old style, has to be 'cause the cap is larger in diameter.
  9. NAFORD302
    NAFORD302 Member
    SILEX MO
    It Is A Small Cap
  10. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Who makes it?
    SBFs never came with a small male cap in stock form.
    Also, I looked up that cap number (c200) on O'Rielly's site and it shows to be for an International engine. Doesn't mention Ford at all.
    Please clairify as I am interested, but cannot find anything on it myself.
    I must be missing something. :huh:
    Thanks
    Dave
  11. scooper77515
    Yeah, this cap is exactly the same diameter, and without using a measuring instrument, appears to be the same depth. It snaps right on the stock distributor.
    We just aren't sure at this point if the rotor is the right height to hit the center contact.
  12. NAFORD302
    NAFORD302 Member
    SILEX MO
    I Should Find Out Tomaro I Will Pull Cap Off 289 And Take With Me
  13. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    I got my adapter for the 2-peice cap assembly at CHECKERS.....for like $9 something
  14. scooper77515
    The one we are talking about that appears to fit is NAPA #AL162. The OReilly C200 was a big cap. The NAPA looks just like the stock cap except for the nipples.
  15. ratio411
    ratio411 Member
    Pensacola
    Looks right.
    That's cool...
    I looked it up by part number, but it doesn't say what vehicle it is meant to fit.
