The Milodon front sump pan,is 11in across the sump.Being 11.75 between suspension parts gives enough clearance. same basic shape as Canton but more detail to fitment with the Milodon pan.JMO. Ron
Although the Milodon pan I have is pretty old, I still had to slide the motor foward for the bottom of the pan to clear the A arms. I removed the radiator and the engine/trans did slide out enough to get it up and out together, but it was at a pretty steep angle. As you can see in the picture the pan just clears the A arms..............not by much though.
