Car has been sitting for a while...
Discussion in 'Technical' started by NewMaverickGuy, Jan 26, 2018.
  1. NewMaverickGuy
    NewMaverickGuy Member
    Birmingham, AL
    1970 Ford Maverick
    A manual choke would be even better.
  2. Acornridgeman
    Wisconsin
    Take the black cap off and see what is in there. It could be just disconnected or out of adjustment.
    I see the electric conversions on ebay for $25-$30 - but I have no idea of their quality. Mechanical or electric, both are easy to work with and both use the same principle of heating a spring to change the tension on the choke plate.
  3. Craig Selvey
    Until you get the car running and ascertain the condition of everything else....I wouldn't worry about fixing the choke right now. Get it running first.
    junrai, mojo and Krazy Comet like this.
  4. NewMaverickGuy
    Birmingham, AL
    1970 Ford Maverick
    I figured it would make things a lot easier trying to get this thing running.
  5. Craig Selvey
    You can work around that issue (if it has one) until you figure out what all is going on.
  6. NewMaverickGuy
    Birmingham, AL
    1970 Ford Maverick
    It doesn't function. It's supposed to be spring-loaded closed and it's not
  7. Krazy Comet
    Yes at 30-40*, at 65+ isn't going to make that much difference, carb probably needs rebuilt anyway... Oftentimes why a 6cyl was parked, carbs are junk after 6-8 years of operation... If it was so-so, no doubt worse now...
    The black housing is adjustable, loosen screws and it rotates to adj... If it doesn't move choke flap, probably the finger to linkage isn't in spring as it should be... There are 357* of rotation to get it wrong and maybe three that's correct(I'm allowing 3* of slop in spring loop)... If spring fits into slot, you have less margin of error...
  8. NewMaverickGuy
    Birmingham, AL
    1970 Ford Maverick
    I'll try it as soon as I can. Darn rain is holding up my progress
  9. NewMaverickGuy
    Birmingham, AL
    1970 Ford Maverick
    Well I was finally able to test it. Turned out the carb needed a rebuild (of course) and a fuel pump. Put it all together today and it's aliiive! Runs pretty good, just gotta dial in my idle and perhaps a couple other things.
    71gold likes this.
  10. Acornridgeman
    Wisconsin
    Thanks for the update ............ :thumbs2:
  11. NewMaverickGuy
    Birmingham, AL
    1970 Ford Maverick
    Well I'm in a real pickle now. I went out to try to start this thing again and it'll ignite for a second and then immediately die, as soon as I let off the key
  12. Craig Selvey
    I had a car doing the same thing. It ended up being the starter solenoid.
