Car just sputters when I try to start
Discussion in 'Technical' started by NewMaverickGuy, Feb 22, 2018.
  1. NewMaverickGuy
    NewMaverickGuy Member
    Birmingham, AL
    1970 Ford Maverick
    I got it guys. Now I just have to do the brakes. One line was left off a drum and the brake fluid looks like chocolate milk
  2. yellow75
    Tillamook Oregon
    Glad you got it figured out, what did you finally do to remedy problem ? It is nice when people let you know how problems were solved so others can learn or if the people that tried to help you steered you in the right direction.
    A rusted out fuse block will probably lead to future problems and is a symptom of a rusted out cowl or bad windshield rubber of which both are a common issue
  3. NewMaverickGuy
    Birmingham, AL
    1970 Ford Maverick
    I had to adjust the ignition switch. All I have to do is pump the gas pedal once and crank it and it runs and idles just fine, no problems. I initially had to adjust the idle mixture because it would bog under throttle. But I leaned the mixture and now no problems (y)
    71gold likes this.
  4. yellow75
    Tillamook Oregon
    Thank you
  5. NewMaverickGuy
    Birmingham, AL
    1970 Ford Maverick
    Thank you to all of you. After all, y'all are taking time out of your day to help me with my greenhorn questions.
