car times
Discussion in 'Drag Racing' started by Rocket!, Oct 5, 2010.
  1. Rocket!
    Rocket! Member
    Philadelphia
    1971 maverick grabber
    my car hestates off the line I had 31 squirter size in there with the 50cc put the 30cc pump and it got worst so i put 37 squiters with the 50 cc pump
  2. bossmav
    bossmav Drag racing nut
    Harrisonburg, Va
    74 Grabber now Pearl white
    Good advise!
    BINGO! Real good advise(y)
    Rocket, it's not about how fast you go, it's about seeing the win light come on!
    Now I understand completely how you feel but slow down don't get upset and do one thing at a time, that way you can see if you are moving forwards or going back. I wouldn't spray the motor until you have got these issues fix.
    Just my .02
    Bossmav
  3. Rocket!
    Rocket! Member
    Philadelphia
    I changed my carbs main body and my car now runs a tad bit better off the line I got a 1.818 60ft and 1/4 time was 11.862 at 115.84. But the car was stumbling a bit on top end my carb is still a 750 but there reason I changed the main is beacuse one of the squirter threads wore out and striped. that carb has been in use since the 70's.
  4. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    I see you still haven't addressed the 60ft times, spring for some Cal-Tracs!
    IMHO, you should be able to get that car down in the mid 1.40 range. My 6 cylinder turbo'ed S-10 pulls high 1.60's on street pavement with Nitto 275DR's and a soft launch...
  5. Rocket!
    Rocket! Member
    Philadelphia
    I still have wrong converter but just changing the carb base picked up my 60 ft a bit
  6. Rocket!
    Rocket! Member
    Philadelphia
    ok on juice my car loves it with small converter
    60ft-1.336
    330-4.004
    1/8-6.283
    mph-106.17
    1000-8.298
    1/4-10.029
    mph-130.04
    Car pulled the wheelies off the ground and hauled ass
  7. Wilbur Green
    Wilbur Green Member
    Plymouth, Ohio
    76Stallion, 762dr.
    Good times on that run on the juice.
  8. olerodder
    olerodder Member
    NorCal
    Very impressive times on the juice.....................next thing you know you'll be in the magic zone......................the 9's.............................
