Car won't start
Discussion in 'Technical' started by adam 72, Nov 28, 2011.
  1. golden bullet
    golden bullet Member
    eagle, ID
    1972 mercury comet, 1971 chevy c-10
    check to see if you are getting 12 volts to the "s" terminal on the solenoid when the key is in the start position.
  2. Streamliner
    Streamliner Member
    Sounds like the starter motor is spinning but the drive gear isn't engaging the flywheel
  3. Craig Selvey
    Dittos to that.
  4. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    So maaybe the teeth on the fly wheel are worn. And can that happen literally in a kminute. Starts once. Off. Then doesn't start
  5. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    So could the tteeth on the fly wheel be worn. And can that happen in a few minutes.
  6. Streamliner
    Streamliner Member
    No, it means the bendix gear in the starter isn't being kicked into the flywheel so the starter motor itself is spinning without being engaged into the flywheel...I've had them do that and hit the starter motor a few times with a ballpeen hammer then they worked fine
  7. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    Well ill check my battery, the connections, make sure everything works then I'll mess with the starter motor. Thanks for having this knowledge guys. I really greatly appreciate it
  8. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    So I just tapped the starter a bit and it has a different sound. I seems like its almost engaging.
  9. TJC47
    TJC47 Member
    INDPLS, IN
    FORMER OWNER 72 COMET G.T., 03 Mercury Marauder, 64 Ford Fairlane.
    Replace the starter drive unit, sometimes referred to as the Bendix.
  10. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    So I'm thinking my problem has to do with the starter or part of it. The battery is good and I cleaned the connections. It didn't start in neutral either.
  11. Bryant
    ill repeat myself.
  12. TJC47
    TJC47 Member
    INDPLS, IN
    Starter drives are cheaper to replace than the motor. Take the starter
    off and have it tested at AZ or some other store that will test it free.
    I've replaced many starter drives in the past and they're easy to do.
    I've been a mechanic for over 55 years and turned wrenches on my
    brothers 1971 Comet which won several drag races.
  13. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    I had them test it but looking back I'm skeptical. He had trouble hooking it up. I got the car to start ywsterday. I cleaned up the battery's terminals and all the connections. I tapped on the starter. Turned the jkey.it worked a few times. Once I closedthe hood it stopped
  14. TJC47
    TJC47 Member
    INDPLS, IN
    Get a remanufactured starter with the lifetime warranty and try it.
  15. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    I think that's what i shall try. Thanks for all the help.
