Carb keeps flooding.....
Discussion in 'Technical' started by NJShoreMav73, Aug 19, 2009.
  1. NJShoreMav73
    NJShoreMav73 Member
    Central, NJ
    73 Maverick- 2 Door, LDO Trim, 302, Bucket Seats, Automatic on the floor.
    I have a 6 cylinder in my 70 Grabber.
    It was running perfect and then last week it started to give me problems. Cold start is perfect and it runs great!!! I drive it around and it still runs great.
    After I shut it off and let it sit for a little bit I try to start it and its flooded. I can get it running by holding the pedal to the floor, and then it runs like crap. Once it starts to idle (barely) it will run rough, gas will spit out of the bottom of the carb and it stalls.
    I had it rebuilt by a reputable shop, installed it and it ran great....then after driving it for an hour it did the same thing again.
    What can it be? I'm trying to avoid swapping my 302 from my '73 in it since its like 100 degrees out.
    Anyone have this problem? Could the carb just be bad?
  2. justin has a 74
    kentucky
    turn down the idler screw... its just running to rich probably it gets hot out these days
  3. chirt
    chirt Carlos Hirt
    Massachusetts
    humm, I don't know much about carbs but sounds to me like the float might be set too high or the valve on the inlet tube where the float hits Don't know how it's called" is not sealing good:huh:
  4. NJShoreMav73
    NJShoreMav73 Member
    Central, NJ
    I just had a thought......
    Could the fuel pump be bad? Maybe it's pumping too much fuel and causing and causing too much fuel pushed into the carb?
  5. Mavman72
    You have a float/needle and seat problem or a percolation problem.Fuel gets hot in float bowl and starts to expand and leak into intake. This will cause the hard start/flooding condition you are experiencing.
  6. Mavman72
    The only thing I can think of as far ar the fuel spitting out the bottom??...of the carb.
    Cold fuel hitting hot fuel in the float bowl.Toss an ice cube in boiling hot water...it will literally explode from the temp variation.Cold fuel will absorbe heat faster than hot fuel will cool off...soo on that theory.The fuel is expanding rapidly in the float bowl causing it to pump itself out the boosters.Or I could be so far off base that you think I am nuts...
    Does your choke work properly???
  7. Mavman72
    Sorry I am on a tangent here...Fuel is spitting out the bottom of the carb?
    Spitting out,into the throttle bores??
    Or is it spitting out onto the intake from between the carb and intake gasket???
  8. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    Steve, I think Next weekend is clear to swap that engine in, we need to find out if the C4 will fit your trans tunnel with out modification though
  9. 71gold
    C4 into a '70...:thumbs2:...crossmember and driveshaft will work also...
  10. NJShoreMav73
    NJShoreMav73 Member
    Central, NJ
    You're a bad influence Shaun!
  11. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    nah, I broke my throttle cable and that was reason enough for me to swap in the 5.0
    Thanks Frank!
    FFS
