Carb problems
Discussion in 'Technical' started by chase259, Apr 8, 2014.
  1. chase259
    chase259 Member
    Calgary, AB, CAN
    1970 ford maverick
    What is the best keyed source tho?
  2. groberts101
    groberts101 Member
    Minneapolis, MN
    What about the radio or the even the washer pump?
    IIRC.. and I often don't these days so add some extra salt.. I used to run the very few E-chokes I've used through the years right off the coils main 12V keyed lead. Or maybe it was the oil pressure sending unit? That way you aren't adding much in the way of new wiring and it can be loomed up nice and neat from the rear of the manifold.
  3. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Plug it in using the existing factory wire than ran to the electric choke on the old carb.
  4. chase259
    chase259 Member
    Calgary, AB, CAN
    1970 ford maverick
    The old carb was manual
  5. chase259
    chase259 Member
    Calgary, AB, CAN
    1970 ford maverick
    What's the voltage if I ran the wire straight to the ignition?
  6. groberts101
    groberts101 Member
    Minneapolis, MN
  7. chase259
    chase259 Member
    Calgary, AB, CAN
    1970 ford maverick
    Okay so now I'll just run threw with a voltmeter, but if any suggestions that would be sweet
  8. baddad457
    Exactly ! Hot ignition, the correct initial timing, an EFI type cam and a smallish carb = no choke needed. I've had one Explorer level carbed 5.0 fed by a 570 SA Holley that would fireup and idle at 25*F without ever touching the go pedal. JUst crank it and wait a couple seconds for it to fire off
  9. chase259
    chase259 Member
    Calgary, AB, CAN
    1970 ford maverick
    Okay so I'm planning on running the choke wire through the fire wall to the fuse box but does anyone know a fuse spot that gives me 12v?
  10. baddad457
    Yea, any of the fuses will get you 12V. What you may want though is the amperage requirement of the choke, not the voltage.
