Carb Recommendations
Discussion in 'Technical' started by Masta T, Jan 19, 2014.
  1. Bryant
    you can mix intake and carb brands.
    another vote for holley. ive wasted so much time on edelbrock carbs i want some money back from edelbrock.
    baddad457 likes this.
  2. baddad457
    Yea, x 2! Holleys need no adjusting once they're tuned and set up for the engine. If you're adjusting it, then you've got problems other than the carb causing the "need" to adjust the carb frequently.
    BBMS18 likes this.
  3. baddad457
    My recommendation is an RPM, Weiand Stealth, Ford C9OX, A321, Shelby Cobra, or Edelbrock's old F4B. Topped with a Holley 570 Street Avenger. If you want to forego a 4 bbl intake swap, just replacing the 2 bbl with a Holley 4412 500 cfm 2 bbl will give you 4 bbl performance in a 2 bbl package.
  4. mavgrab302
    I agree with the 500cfm holley 2bbl.. I had a 66 mustang 302 with a mild cam and long tube tri-y headers, My budget didn't allow me to buy a new intake at the time so I bolted a new 2bbl on my stock intake and WOW!.. I never even considered switching to a 4bbl after driving the car...
  5. Craig Selvey
    It has been my experience that Holleys will start to leak around the bowls because of the way they are made. This is why I went with an Edelbrock.
    Is there a secret to getting a Holley not to leak?
  6. Krazy Comet
    Dismal Swamp
    The newer Holley gaskets rarely leak, the old cork type of 15-20 yr ago were mostly junk...
  7. groberts101
    groberts101 Member
    Minneapolis, MN
    yep.. and the even cheaper off-branded paper gaskets were worse yet. The newest Teflon coated removable's are very slick.. and a tad of chapstick or wax makes them almost indestructible.
    I won't go much past a simple generic comment here.. but I would easily concede to the Edelbrock having a better design from a "potential leak" standpoint. But.. it gives up modular design and component flexibility in doing so. Which is exactly why you can buy hot-rodded parts(form AND function).. for every single piece of a Holley.
    I would say to just find yourself a street version of a Holley 600 with vacuum secondaries, electric choke, and a Ford auto-kickdown bracket. Plenty out there to chose from based on cost and it'll run well with not much more than simple maintenance being required over the long run.
  8. Craig Selvey
    Thanks for the tip. I haven't rebuilt one in about 15-20 years.
  9. baddad457
    My 3x2's are nine years old. No leaks here. :naughty:
  10. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    The only leak I ever had on a Holley was when the throttle blade shaft wore out.
    I've never had Holley gaskets leak.
    With that said, I currently run a 600 Edelbrock, and it runs great.
  11. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    The new 625cfm(2012? Release) street demon looks awesome
    Seems to be a carter thermo quad / rochester q jet hybrid
    This will be my next carb for sure
    Ive had every type of carb and most had sone type of flaw
    When demon was owned by barrygrant. They had quality control issues
    My 750 speed demon was pretty much junk out the box
    Never cared for a holley..currently on my maverick..600cfm
    Q jets seem only worth it if you can get a specialist to rebuild/mod/tune like john osbourne has over the years...but he no longer does thiz.
    Edelbrock afb performer was eh..usualy a stumble no tuning can cure..
    Their avs is ok running good..but got better performance out of a q jet
    Never had a actual thermo quad
    Check reviews on the new street demon allot of ppl love it over the carbs theyve swapped from
  12. mav302
    mav302 Member
    Baxley,Ga
    1970 ford maverick
    holley
    Holley hands down...runnin a 670 on my 302...might be alil bit big but i can use it on several engines...simple to adjust and when u get it right nothin will run better than a holley..they arent too bad on the price
  13. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    Seriously if you want a carb out the box consider this
    http://www.demoncarbs.com/1901.asp
    you can get it in an all AL body too if you want
    These have Triple stack Boosters
    Will have just about the best throttle response over any carb..def any Holley or edelbrock that's for sure
    to me, Holley is best for a straight up track car, but for street theirs better choices
    more power isn't everything
    streetcar will want a tad compromise on power for better throttle response and mpg
    Which is why Ive always like my Q-jet on my Buick, best all around carb
    Seriously Google and YouTube reviews on this carb I don't think anyone was disappointed after the swap and all praised it over the carb they swapped out for weather it was Q-jet, Holley, and Edelbrock
    I plan on swapping out my carbs for both Buick and ford for this
  14. bmcdaniel
    That's an interesting carb, wish I could try one without buying it first.
  15. baddad457
    Just be advised that the plastic body in this carb can warp over time as did the ThermoQuad it was based on. ThermoQuads were great performers, but due to the plastic body, they didn't age well. They're virtually extinct today.
