Carb Recommendations
Discussion in 'Technical' started by Masta T, Jan 19, 2014.
  1. baddad457
    Although I've never run Webers, the part I've always heard about (mostly from those who've never touched them) the synchronization is likely BS. I had no problems setting up my 3 twos or the two 4s' (on my 427) Those carb pads look like they're sitting on a common plenum so there's really nothing to worry about in synchronizing them as far as A/F mixtures. The linkage would likewise be pretty easy to get em hooked up right. That you do before ever firing it up. The hard part is the $$$ outlay. Once you have them set, they should stay that way for years, if Webers are anything like Holleys. Multiple carbs got their bad rep back when everything had points ignition, it wasn't the carbs getting out of whack, it was the constantly changing dwell angles with the points wearing. Doubly so with a dual point distributor and their stiffer point springs. I tried a dual point dizzy in my 427 for a few months once, it ran no better than a single point with a good set of points and an Accell Super coil. The extra set of points was really only needed for high rpms. Anything under 6500, it wasn't needed. I'm running a stock Duraspark in my 331. No problems with it up to 7 grand.
  2. Shorty
    Shorty Member
    Lafayette, In
    See, someone brighter than I set me straight. Actually they are not on a common plenum, they each go straight to a head port. Webers would still work, right? When I was dream wheeling about this I thought of having a plate made to mount a supercharger but that would have to be a different engine build.
    Bruce
    baddad457 likes this.
  3. baddad457
    LOL. I looked up Weber carbs and someone's got em listed on Amazon (all 4 in stock for $400:thumbs2:) and Walmart. Cheap too. But their bolt pattern's different than what you have. Maybe Stromberg or Rochesters. Have to look those up.
  4. baddad457
    Got to be Rochesters. Strombergs have a three bolt pattern.
  5. Shorty
    Shorty Member
    Lafayette, In
    I always figured that I would have to get adapters made to install Webers. It would certainly look exotic under the hood of a 'lowly' Maverick.
    Bruce
  6. bmcdaniel
    Local guy with a big block has independent runners with four 2-barrels, don't know what kind. Could never get them to run right with the wide rpm range needed on the street. Finally sold the carbs for ridiculous money and bought EFI lookalikes. Problem solved.
  7. baddad457
    I'll bet the carbs combined were likely too big. All too common problem with those who don't understand what makes them tic.
  8. mvw66gt
    mvw66gt Member
    Arthurdale, West Virginia
    71 Comet GT
    That 4 deuce intake looks like it would take the 3-1/4" x 1-7/8" small base Rochester carbs. - Matt
  9. Shorty
    Shorty Member
    Lafayette, In
    Out of curiosity I just measured the stud holes and they are 2 11/16" x 3 7/8". At one time I was looking at Mikuni 2 barrel carbs but didn't pursue it. Where would I find this type of information for different makes and models of carbs? And what brand was the efi look a likes, bmcdaniel?
    Thanks,
    Bruce
  10. baddad457
    Try looking uop Weber 32/36 DGV carbs . Those might fit that intake
  11. bmcdaniel
    Don't know for sure but they looked like this setup from Borla.
  12. Shorty
    Shorty Member
    Lafayette, In
    Those look awesome and what I envisioned for this intake if I ever use it. Right now I'm satisfied with the dual quads and the next step of my project - chassis (four link & tubs) and interior work.
    Bruce
  13. baddad457
    :tsk: Shame on you for posting porn here :thumbs2:
    RMiller and Shorty like this.
  14. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Sure is sexy isn't it?
    Shorty likes this.
  15. baddad457
    Very ! :thumbs2:
