Carbs and HP
Discussion in 'Technical' started by Racer_X, Jan 16, 2012.
  1. baddad457
    He's probably running it with annular boosters too, that makes a big difference for a big carb on a small engine.
  2. bmcdaniel
    Yep, annulars. And a dual plane intake so each cylinder only "sees" half the carb.
  3. Joe Dirt
    A 4118-S is a 725cfm carb. Should be a dual feed ,heated choke, single pumper
    The R-4118 is holley's universal replacement same cfm choke. May vary
    Oe application for a 4118-s for a 68 hi-po 289 that being said I would run it it being a vac-secondary it won't let anymore air then needed through the secondary venturies.
    If ford and shelby thought enough to run it on a 289 why be scared to run it on a 302
    If you don't run it I might be interested in buying it
  4. ShadowMaster
    ShadowMaster The Bad Guy
    The ShadowLands
    1969 1/2 Maverick
    Run the 725. Toss the Edelbrock into the street and watch it get run over. Open beer.....smile.
