carburetor air filter housing
Discussion in 'General Maverick/Comet' started by russellgaspard, Apr 15, 2015.
  1. russellgaspard
    russellgaspard Member
    united states
    1973 Ford Maverick 250 Inline 6
    I had work done on my car and had the carburetor replaced with this one on my l6. The old housing doesn't fit the new carburetor. The old housing has a recess, (bowl like shape) under it so it didn't sit to high. Does anyone know what housing I need to get for it to fit under the hood with this carburetor?
  2. russellgaspard
    united states
    This is the car so you can see the hood. It's the regular hood.
  3. Acornridgeman
    Acornridgeman MCCI Wisconsin State Rep Moderator
    Wisconsin
    So your stock air cleaner housing doesn't fit? That looks like a YF, same as a Maverick uses. I guess I'm missing why it will not go onto that carb in your picture? Is your air cleaner not a Maverick one?
  4. russellgaspard
    united states
    The original was a Carter single barrel carburetor but a different one than this one. I guess this is a later model of it. The housing for the old one doesn't have a big enough hole to fit to this one.
  5. russellgaspard
    united states
    This one is like the original one that was on it before
  6. Acornridgeman
    Wisconsin
    Yes, Carter RBS and the Carter YF were both used in the Maverick depending on what I-6 motor you had. But I didn't know the air cleaner housings were different. I thought they had the same size opening ............ :huh:
  7. russellgaspard
    united states
    Do you know where I can find a housing for the YF?
  8. Acornridgeman
    Wisconsin
    I'm sure you can find one super cheap by placing a wanted ad in the classifieds - but hold off a minute until someone can confirm if there is a difference in the air cleaners for a YF and an RBS. I am still thinking they are the same for all I-6 Mavericks.
  9. russellgaspard
    united states
    There is a difference because I tried using my old housing on it and it wouldn't fit
  10. Acornridgeman
    Wisconsin
    What is that YF you have from? They used YF's on dozens of different cars including Mopar and Jeep. Is that a Ford YF?
  11. russellgaspard
    united states
    Motorcraft I believe
  12. Acornridgeman
    Wisconsin
    I just measured the Maverick YF carb - it has an opening for the air cleaner of 2 5/8" - what is yours?
  13. russellgaspard
    united states
    It's the same. But my rbs had a 2 1/3" opening
  14. Acornridgeman
    Wisconsin
    Learn something new everyday .................... :yup:
    I would say throw an ad in the classified wanted section. One of the guys will have one for you.
    The YF is definitely 2 5/8"
    russellgaspard likes this.
  15. Eastern Raider
    Eastern Raider Member
    middle Ga. warner robins
    Yall have to consider the choke housing, is sometimes up on the top side. Some Filter housings have clearance for this, a domed area. If this is not an issue ,the housing could be enlarged!
