Carburetor and intake question
Discussion in 'General Maverick/Comet' started by classic ccg, Nov 26, 2015.
  1. classic ccg
    ringgold GA
    72 maverick
  2. Static
    Static Member
    Apache Junction AZ
    1975 Maverick 2 Door
    I went with a similar setup but used a Holley carb instead. Dont like the edelbrock carbs.
  3. classic ccg
    ringgold GA
    72 maverick
    If you dont mind me asking why did you go with holly is it better
  4. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    It's a matter of personal preference. Both Edelbrock and Holley make good carbs.
    Craig Selvey and William623 like this.
  5. mav man
    mav man Member
    wi
    70mav
    Not a fan of edelbrock
  6. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    If you want more performance get a Holley. If you want to slap it on and go and never mess with it get an Edelbrock.
  7. z28th1s
    Lynchburg, VA
    Also not a fan of Edelbrock carbs.
  8. Hotrock
    Munroe Falls, Ohio
    From my experience the combination of the Weiand Stealth dual plane and Summit 600 CFM carburetor at the following links offer the best trouble free performance in their price range. (The Stealth is a taller manifold than the Performer however, hood clearance is not an issue.) The Stealth is also a more aggressive manifold then the Performer. They are both on sale at Summit Racing!!!
    Check out the customer reviews. All you will need is a set of manifold gaskets, correct color RTV for the manifold ends and an in-line filter.
    I ran this combination for a number of years before switching to a Speed Demon carb. The Speed Demon is more finicky than the Summit carburetor.
    http://www.summitracing.com/parts/wnd-8020/overview/
    http://www.summitracing.com/parts/sum-m08600vs/overview/
    rotorr22 likes this.
  9. 71maverick361
    71maverick361 Vern Isaac
    Odem
    71 Grabber
    I would also go with the Weiand mani and Holley carb setup I have had great performance with them
  10. classic ccg
    ringgold GA
    72 maverick
    I just ordered them thank all of you for all of your advice
  11. Static
    Static Member
    Apache Junction AZ
    If I had to do it all over again I would also run the Weiand manifold
  12. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    That Stealth is one of the best dual planes out there for the 302 and it is one of the most inexpensive. The Eddy RPM air gap may or may not be superior, but is significantly more expensive.
  13. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    That's because the Stealth is made in China.
    Static likes this.
  14. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    I love my stealth seems well made to me
  15. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    I too prefer the Stealth, but when it came time for me to get one I searched craigslist and ebay. The reason was that I wanted an earlier version that had the rear water crossover. I believe all the newer ones only have the front crossover which is typical with all small block Ford aftermarket manifolds. Ultimately I found one locally for less than $100 that showed little use.
