Carpet installation
Discussion in 'Cosmetic' started by scooper77515, Jun 6, 2007.
  1. Rando76
    Rando76 Member
    Claremore, OK
    Hey Tom,
    I've got the same seats and interior color in my '73. (y)
    I'm going to look for insulation today at lunch. I'll let you know. Are you sure you need to glue anything down? The factory didn't glue any of it down did they? I don't think the tarpaper material was glued down. :huh:
  2. blugene
    I'm gluing my jute but not the carpet...i'm just waiting to here where it's being found. I did see it at a rod shop nearby so I will go there this weekend if I miss it today. I will have pics and specs when I return...(of the jute)
  3. scooper77515
    I just bought 6 yards of jute, should be enough to do the entire floor back to the trunk, inside all the kick panels and rear seat armrest panels, and maybe some left over for the trunk.
  4. Scotty P
    Scotty P Member
    santa rosa, ca
    I had my carpet installed last night. They glued both down. Hmm, hope I do not need acces to the floor or need to do any welding under the car!
  5. scooper77515
    How does it look and feel glued down?
    The glue I was planning on using was just the 3M spray adhesive. I am pretty sure I could pull the carpet up pretty easily if I ever needed to.
  6. Scotty P
    Scotty P Member
    santa rosa, ca
    Looks and feels fantastic. The "hump" is tight and the space between the split rear seats came out very nice. I think I saw the 3m adhesive on the shelf but it may have been for the door panels I had them do as well.
  7. scooper77515
    Do you know if they used a jute or other insulating layer?
  8. Rando76
    Rando76 Member
    Claremore, OK
    Found it!!
    I found the insulation at Home Depot. A 24" x 25' roll is $24. They had a roll that was 4' x something , but it was $40 something. I think this will work well. I'm planning on taping the seams with metal tape. I'll try to take pics the installation this weekend.
  9. Scotty P
    Scotty P Member
    santa rosa, ca
    Jute and other "reflective stuff" for heat.
  10. scooper77515
    Thanks Rando, I will be going by a Home Depot this afternoon. I will try to snag some of that.
    So what do you think, put the aluminum stuff at the bottom and all the other stuff on top?
  11. Scotty P
    Scotty P Member
    santa rosa, ca
    Yeppers
  12. Rando76
    Rando76 Member
    Claremore, OK
    The other being the jute? Yeah, I'd do that. :thumbs2:
  13. scooper77515
    That is my plan at this time. I will take pics as I do this and post them. Of course posting final pic unless it looks like crap or I screw it all up:cry: :huh:
  14. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Never throw jute away. Good for soaking up oil spills or to lay under your engine. Heloise
  15. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I don't know that I like this idea, and it will probably get alot of flack...
    My uncle has the habit of fiberglassing in his floorpans.
    He cuts and lays the mat in over the entire pan after he strips and cleans it, then he puts the resin to encapsulate it.
    It actually looks pretty good, and if the rust takes hold again, he still has a floor that won't be going anywhere.
    Again, I haven't done this, and I still haven't decided that I like the idea.
    But it sure seems it would protect the floors from moisture attacks from above, like a leaky cowl for example. Would also act as an insulator.
    Thoughts?
    Dave
