Cars are never done ... today's project ...
Discussion in 'Cosmetic' started by dmhines, Jun 9, 2006.
  1. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Your's is actually hooked up like factory. Mine is backwards but the configuration I am using worked better with the connections on the air cleaner I am using.. :) I am running the PCV on the Passenger side ... see the yellow arrow for the hose. Yes ... the charcoal canister is hooked up and functional ....
  2. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Idea:
    Gut the canister and put your nitrous solenoids in there.
    Run the nitrous lines into the air cleaner housing.
    Hidden! :D
  3. Mavaholic
    Looks great to me!!
  4. waynes fords
    waynes fords Member
    fayetteville,Georgia
    1973 grabber,2004 ford dually,2000 gulfstream motorhome,2003 ford expedition,66 mustang gt
    yes and Roundup 2005 Dan took best of show!!!!!!!!!!
  5. scooper77515
    Nitrous...fed through the charcoal canister...I like that!!! Stock look, plus 50-150 extra HP (y)
    Wish I wouldnt have tossed mine out, now!
  6. blugene
    Anybody got one they don't want?:evilsmile
    That undercarige looks darn good! Talk about insperation.:dance:
  7. dmhines
    Cumming, GA
    Update on the Rubber Strip. This was called the "Deflector Assembly" in the Assembly manual I have. The manual indicates it was only installed on 302 V8 cars that had A/C or 250 I6 cars with Automatic Transmission. Since a 3-speed was not an option on the 250 I6 until 1974 I would assume all 70-73 250/I6 cars should have had them from the factory.
