change a crank with the engine in the car
Discussion in 'Technical' started by bartikus, Feb 11, 2012.
  1. mav1970
    I've changed rod and main bearings laying under the car but never a crank. If you get to the point of changing a crank, you're also at the point that the block should be taken out of the car, cleaned and checked by a machine shop :yup:
  2. Resto
    Resto Benders Evil Twin
    Yuma AZ
    I would not do that. I would pull the motor. strip it and take it all to a machine shop for a complete rebuild. IMHO short cuts are a crap shoot if you lose you end up with crap.:dance:
    If your bearings are shot you might need a head job, Just sayin.
  3. darren
    Its not going to be fun especially with an inline 6. Thats a big hunk of metal to be messing with on your back. By the time you unbolt and move the trans back your only a few bolts and hoses away from pulling the engine. Its too easy to damage something or make a mistake when your doing it on your back. Your going to get tired,sore and pissed off. You dont want to be any of those when your putting a lower end together.
  4. mrbrooksy
    mrbrooksy Retread
    Motor city
    72 maverick,99 cherokee,2000 cherokee.80 suzuki ts 250 and a minivan
    I agree with the rest really should pull unless you find the oil pump screen plugged or pump loose .main brgs and even rods are very doable but it is a patch may last years and might not. put a high volume pump in also. mhoss
  5. Craig Selvey
    I wouldn't mess with any of it. Good running, low mileage 6 cyl engines come up for sale all the time. Buy one of those.
  6. bartikus
    bartikus Member
    salt lake city, ut
    i've been looking in utah for the past few months for a different engine. but no luck. i'm going to do a compression test on the motor later today to see where that is at to determine how much wear is in the piston bores. if that all comes out good then i will pull the pan and change my pump and check the bearing caps. if i need to do the work on it then i will pull the motore to do it. i figured it would be easier to pull the motor but i wanted to ask and find out. this is my daily driver and i can't have it down for too long.
  7. Craig Selvey
    Since it is your daily driver...I would continue to look for another motor that you can either:
    1. drop in and go
    2. Rebuild the used motor and continue to drive your car. When you get the used motor rebuilt, makde the swap.
