Changing Shocks Myself
Discussion in 'Technical' started by maxsideburn, Mar 6, 2004.
  1. maxsideburn
    maxsideburn Member
    Lafayette, Louisiana
    1976 Ford Maverick (200CID I6/AUTO)
    um........there are two bolts on top (under hood), and one on bottom. Anyone know what size the one on the bottom is??? I've tried every wrench and socket I have and nothing fits it right. It's not stripped....but nothing is fitting it right and causing it to strip. I just can't get a break, heh.
  2. Bluegrass
    Bluegrass Jr. mbr. not really,
    Easton, Pa
    73 Comet GT, EFI, C4, Posi
    It must be them La. tools.
    There all standard SAE sizes. Not metric.:)
  3. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Actually there are two nuts on both the top and bottom of Maverick front shocks ... :D
    Tip - remove the bottom nuts first. DO NOT JACK UP THE CAR. If you jack up the car the lower A-Arm will block the nuts as the coil spring decompresses ...
    You will also need to remove the upper shock mounts to remove the shocks. If the bolts are rusty soak them overnight with a rust desolver. If you start spinning those bolts inside the shock tower they really suck trying to get out.
  4. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Max, in my drinking days I usually changed my socks before noon, before I got too drunk. Somedays I had my wife help me change my socks. It always seemed best to do it sitting down, and one foot at a time. As my drinking progressed, my desire to change socks dwindled. I would only change socks maybe once a week, and that was due to the insistance of my wife. Once I became clean and sober I found that changing socks was easily a daily event. Now, thru the help of many self help programs I even feel compelled to change socks multilple times a day to meet fashion of the clothes I change into. So, dont feel as if this has not happened to others. Maybe it is prevalent in people with the Maverick/Comet bug to once in awhile ask for help in changing socks. Carry on man! We are here for you!
    Dan
  5. Bluegrass
    Easton, Pa
    Dan, Iwould have never though that of you.:) :)
  6. bmcdaniel
    If you do want to jack up the car, first place a block of wood beneath the upper control arm and the frame (?). The arm won't drop so far and the nuts are accessable.
  7. bmcdaniel
    Dan, changing socks...
    :clap: :clap: :clap:
  8. dmhines
    Cumming, GA
  9. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    LOL@Dan!
    Don't ask a shock to do a springs work. Shocks dampen spring oscillations, not support load. If you haven't fixed that rear leaf bushing you posted earlier Max, you are really wasting your time.
    Oh, and as for the high pressure KYBs, Mustang front shocks are the same, and the rears are a Granada/Ranchero part number, which have been discontinued.
  10. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    Go with Monroe gas-charged OEM replacments. They're $10.88 each with a lifetime warranty, and that's all you need. KYBs are the LAST components you need until AFTER a COMPLETE suspension rebuild is performed. What you are wanting to do is like puting a $3000 stereo system in a $500 car.
    Polygraphite sway-bar bushings also help a great deal.
  11. dmhines
    Cumming, GA
    I usually pick my shock brand by the color! :)
    Went with Gabriel Red Gas in the front and White Hurst in the back ...
  12. Mavaholic
    Geeze Dan, where else can you get this much entertainment for free. Certainly not cable TV. I'm not even going to ask about your underwear.
  13. Maverick Guy
    Maverick Guy Maverick Enthusiast
    NE Ohio
    Dennis, I think I speak for everyone here when I say thank you! :D
  14. maxsideburn
    maxsideburn Member
    got the front shocks changed, car handles much better now. As for the bushings where can I get them? I looked at the autozone website but they don't have them.
  15. T.L.
    T.L. Banned
    Southern Colorado
    P-S-T.com
