Charging
Discussion in 'Technical' started by wolfheads, Apr 17, 2020.
  1. Krazy Comet
    I'm assuming you've been using a charger on battery? A battery with more voltage than alternator is producing defies physics. Their tester can can load test battery & charging system separately, then give a print out. You basically performed same test by checking voltages with with fan running & lights on. Flaky regulator or weak alt can give same results. Unless alt is tested while full fielded, it's a guessing game as to which is causing problem.
    I've seen a couple alternators with a burned connection to one of the diode banks. They did charge but could produce maybe 15 amps. With more than radio & headlights on, voltage would fall below 12v.
  2. wolfheads
    wolfheads MadMav
    Florida
    73 Maverick / 2000 Harley Low Rider
    The results show the alternator was not putting out the recommended voltage under a load.
  3. wolfheads
    wolfheads MadMav
    Florida
    It turned out to be the alternator. I checked it this morning and the alternator is reading 13.45 after installing a new one.
    Acornridgeman likes this.
  4. Acornridgeman
    Wisconsin
    Glad it is getting better for you. 13.45 at idle is OK. Probably want to see closer to that 14 at higher RPM and nothing turned on.
    wolfheads likes this.
