Cheap serpentine setup
Discussion in 'Technical' started by 7D2 Grabber, Sep 29, 2010.
  1. bmcdaniel
    6 grooves and more pulley and belt surface areas means less slip than a standard v belt.
  2. FishnRace
    FishnRace Jamie
    Solomon's Island, Maryland
    '72 2dr 351
    Also, the greater surface area of a serp belt allows for less belt tension, which reduces bearing friction which provides an HP advantage and extends the life of the accessories, AND I've read that a belt tensioner, when used, reduced harmonic oscillation in the belt.
    All new vehicles (maybe not all) are equipped with serp belts so ... must be the better design.
  3. indyman13
    indyman13 Member
    Little Rock, Arkansas
    It all sounds logical. Guess you have to balance that with practical and affordable. There's something for everybody.
  4. dtb147
    dtb147 Member
    Arbutus, MD
    My question is, "Where do you get the stinkin brackets?" :p
  5. rwbrooks50
    rwbrooks50 Member
    Forney Texas
    71 Maverick & 63 Ranchero
    Anyone running serp belt with alt, ac, water pump and crank?
    I would like to the set-up no using the March or simulier system.
    Rick
