chineese crap.... relays are junk
Discussion in 'Technical' started by bomrat, Jun 19, 2015.
  1. bomrat
    bomrat Member
    North Little Rock, AR
    74 Comet 4dr 347 4r70w
    well I am replacing all the Chinese crap relays in installed in my comet. did some real digging and found some industrial relays. I will post soon on how they work. they are 70amp capable, have posts, and are fused.
  2. bomrat
    bomrat Member
    the relays I am going to use. 12v coil 70amp dual post relays... 1 in post 2 out :)
    relay: 37702-1AN0022 cooper busseman. m8 and m6 studs.
    fuses: 0495040 40 amp cartridge Style Fuse Green JCase FMX 32V
    pins: A105220CT-ND CONN SOCKET 15-18AWG TIN
    connector: A106529-ND CONN PLUG 2POS 1.5 SERIES BLACK
  3. bomrat
    bomrat Member
    updated information: they work awesome....
    pins: 282403-1 CONN MINI MIC SOCKET 22-20AWG
    connector: 282080-1 CONN PLUG 2POS 1.5 SERIES BLACK
  4. Rick
    Rick G8I operations
    Ocala, Florida
    You do realize that there's a good chance your new Cooper Bussman relays are made in China right.
  5. bomrat
    bomrat Member
    mexico ;)
  6. Static
    Static Member
    Apache Junction AZ
    1975 Maverick 2 Door
    I like the looks of this style relay. I can see using one of these in my next efan setup.
  7. fuelish351
    fuelish351 Member
    San Jose, CA
    73 Maverick Grabber 2.3 Turbo
    I like the weatherpack GM style ones I get them from the junkyard out of 90's GM cars. They have an O-ring between the relay and connector. I did burn one up running the high speed on my taurus fan, I just run the low speed now and everything is fine. You can usually get a bracket for them off the donor car as well. Here is a pic of them installed in my LS swapped 55 chevy (this was during install its a little more cleaned up now)
  8. fuelish351
    fuelish351 Member
    San Jose, CA
    I do like the ones you have mentioned, they do only seem to be twice as much as a standard style relay depending on where you get it and a lot of times they dont come with a connector. I know the ones I use when they are new are about the same price
  9. 71Mavrk
    71Mavrk Member
    Nevada
    mavgrab302 likes this.
  10. Rick
    Rick G8I operations
    Ocala, Florida
  11. 71Mavrk
    71Mavrk Member
    Nevada
    Ok the relays might be Japanese. Probably none are made in the US anymore. The unit is assembled in the US.
