chromd lifter rails
Discussion in 'Technical' started by JAYSMAV, Apr 23, 2012.
  1. maverick75
    imagine if the 6cylinder got a hemispherical head, that would have been awesome.
    I've heard about the DOHC the aussie engines got at the very end of their falcon 6 run, but i've never seen pictures of the combustion chamber.
    I'm sure they could easily make 300-350HP on a mild NA setup.
  2. olerodder
    olerodder Member
    NorCal
    A lot of years ago there was a drag racer that took some Trick Flow Twisted Wedge heads, cut them in pieces and welded them back together to go on the Ford 6cyld. He had the motor in a Falcon and it was turning in the 11's and this was 10/15 years ago.
  3. maverick75
    Do the 240/300 share the same head bolt pattern as the 302?
    I know the Falcon six 170-250 small sixes don't.
    But they do share the pattern with the tempo 4 cylinder, I've also heard of somebody chopping two of those heads then brazing them together.
    The tempos had a HSC head available which has the same idea as the twisted trick flow heads where they swirl the fuel mixture in.
    http://en.wikipedia.org/wiki/Ford_HSC_engine
  4. injectedmav
    injectedmav Member
    Georgia
    I remember that! That was a pretty cool setup from what I do remember, but I don't remember any specifics about it.(y)
  5. JAYSMAV
    JAYSMAV Member
    Ohio
    '73 Comet 302 LDO auto, '70 Maverick I6
    Wow i've never heard of any of thoes fabbed up heads, that just gets my mind rolling even faster! pretty cool guys, THANKS!
  6. JAYSMAV
    JAYSMAV Member
    Ohio
    rThomas, thanks for that little nugget!
  7. olerodder
    olerodder Member
    NorCal
    Yes, dirt track guys have been doing this kind of thing forever and so have drag racers...............and it goes back to the 30's and 40's when they were modifing Ford 4cylds with special one off heads.................although this is not a Ford it will give you an idea what has to be done to modify V8 heads
    to fit a 6cyld.....................I even think back in the day they used to use Cleveland heads (cut up of course) and put them on Ford 300ci six's.
    With the right tools/time/money you can do anything!
    http://www.cdpautomachine.com/leo/cylinder_head.html
  8. rthomas771
    I remember that Bruce Sizemore used three 351C heads, cut into 6 different sections, to make a 6 cyl head. He was in the high 9's with over 500 hp with this setup. http://1bad6t.com/pdf/HowToBuild500hpSixCylinder.pdf
  9. JAYSMAV
    JAYSMAV Member
    Ohio
    wow! that is some really amazing tech. thanks for the links, man thats some cool stuff. I tryed to look for this stuff on the web and i didnt have any luck. so this is pretty cool.(y)
