Cleaning fuel injectors
Discussion in 'Other Automotive Tech & Talk' started by blugene, Jun 9, 2009.
  1. mavmike72
    mavmike72 Member
    louisville kentucky
    Sorry for the situation between you and your daughter. I agree with you on the learning responsibility, thats a must. I was just messing with you, good luck. :Handshake
  2. blugene
    With the coupon that's another $18 cheaper WOW. My dad is wanting to take a trip to Elgin TX to buy some sausage so maybe I will go with him, if they do same day service. I left a message, thanks!
  3. don graham
    Good luck Gene. I went through the daughter thing too. Everything worked out fine in the long run.:)
  4. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I have had good results this way too.
    I soaked mine for a few days while my truck was down.
  5. blugene
    Guess what! I used the small tube on carb cleaner (Berrymans) and flushed them out from both ends. They look better and the car runs! It runs alot better than it ever has too. I put a can of injector cleaner in the tank also to help if it will. :woohoo1:
  6. mavmike72
    mavmike72 Member
    louisville kentucky
    Good deal.............
  7. chirt
    chirt Carlos Hirt
    Massachusetts
    Glad it worked!:thumbs2:
