Clicking - clanking - clunking - suspension?
Discussion in 'Technical' started by klynam, Mar 15, 2012.
  1. injectedmav
    injectedmav Member
    Georgia
    ball bearing in the rocker panel... :rofl2:
    Sorry, warranty joke.
    70's assembly lines weren't what they are now!
    CA189HJN likes this.
  2. klynam
    klynam Member
    Big D
    1975 Maverick
    Excellent idea - I'll check that - never surrender, never give up!!! (y)
  3. klynam
    klynam Member
    Big D
    1975 Maverick
    Nothing there. I also checked the muffler bearings and the flux capacitor - both were fine. :dancing:
  4. Dave B
    Is it the seat?
  5. blugene
    Could be a marble.. :)
  6. klynam
    klynam Member
    Big D
    1975 Maverick
    Sounds like the best course forward at the present is a 1-2 hour session with wrenches in hand just checking and tightening every darn nut and bolt I can find and get to on this car...
  7. klynam
    klynam Member
    Big D
    1975 Maverick
    Although I laughed about the ball bearing...and initially the marble...the more I think about it, the more sense that makes... :idea:
    The car is 35+ years old and there could very easily be something (screws, nuts, bolts, acorns, etc.) in the fender cavity or somewhere else just jostling around.
    Gonna have to look closely into that...
  8. blugene
    Maybe figure out which side first then go from there..
  9. Craig Selvey
    Rocks in the hubcaps?
  10. klynam
    klynam Member
    Big D
    1975 Maverick
    Didn't find any foreign objects in any unusual places. Though I did tighten up a few bolts here and there, there was nothing so loose as to be causing the noise.
    One thing we have realized: Although we can't make the noise happen, when it does start we can make it STOP with light pressure on the brake pedal.
    So I've ordered the recommended brake hardware kit - going to put that on and see where that gets us...
  11. klynam
    klynam Member
    Big D
    1975 Maverick
    Drum roll please...
    The weird rattling noise was the brakes (or seems to be after a quick drive around the neighborhood) and was fixed quickly and easily with the recommended hardware kit.
    Now the engine seems to be misfiring a little - but that's okay I suppose because now I can start yet another post about our car... ;)
  12. Ryan
    Ryan Ford Addict
    Phoenix Az.
    Glad you got it fixed (hopefully) and it was something cheap.
  13. klynam
    klynam Member
    Big D
    1975 Maverick
    About $15 :thumbs2:
  14. h2o
    h2o Mad Mav Man
    mexico city
    1973 ford maverick gt 289 v8
    Hi!
    One question, I saw pictures of the hardware kit and can't figure out how or where to intall it on the caliper, could you please explain it to me, thank you!:tiphat:
  15. Ryan
    Ryan Ford Addict
    Phoenix Az.
    H2o, the pads on the left of the picture are the inside pads. the anti-rattle clips will clip onto the end of one side of each. If yo uhold the brake pad in position notice which side points down. That is the side you put the anti-rattle spring on. You may need to pinch it a little to get it to stay inplace until you slide it in the caliper bracket. Then the tab that sticks out puts pressure on the pad holding it towards the top of the caliper bracket so it dosnt rattle.
